Old 07-18-2014, 12:58 PM   #1
Lee Sherburn
Default 427/428 ford fe's
What starters are you racers running nhra stock and super stock fe powered cars using?
Lee
Lee Sherburn is offline   Reply With Quote
Old 07-18-2014, 03:07 PM   #2
Bill North
Bill North's Avatar
Default Re: 427/428 ford fe statrer
X2 - I'm stuck with Auto Zone rebuilds b/c nothing else fits headers - HELP!!!
Bill North is offline   Reply With Quote
Old 07-18-2014, 04:18 PM   #3
Tom Nolan
Liked 64 Times in 11 Posts
Cool Re: 427/428 ford fe's
I used the Powermaster Ultratorque starter PT# 9406 250# torque on my 427 High Riser. It has adjustable clocking and shims. Works fantastic. Tom Nolan
Tom Nolan is offline   Reply With Quote
Old 07-18-2014, 05:21 PM   #4
Stephen & Horace Johnson
Liked 166 Times in 54 Posts
Default Re: 427/428 ford fe's
Originally Posted by tom nolan View Post
i used the powermaster ultratorque starter pt# 9406 250# torque on my 427 high riser. It has adjustable clocking and shims. Works fantastic. Tom nolan
x2
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 07-27-2014, 07:28 PM   #5
Lee Sherburn
Steve&Horace Johnson,
Well I bought a Powermaster#9406 and pulled my 20 year old Tilton Super Starter out of my Fairlane race car& installed the powermaster and now my starter relay in the back of my car just clicks when I push the toggle switch. I'm using a Painless Wiring toggle module for all my electrical functions. My tilton seemed to be ok although a friend said it could be pulling to many amps. All I did was hook my battery cable to the powermaster am I missing something?
Lee
Old 07-27-2014, 08:36 PM   #6
Painter
Liked 162 Times in 45 Posts
Starter relay should be really close to the starter. Like maybe on the firewall. Proper size battery cable. Always suspect anthing that says painless. Their switches are not up to my standards.
Painter is offline   Reply With Quote
Old 07-28-2014, 06:11 PM   #7
Everett Hill
Liked 4 Times in 3 Posts
as others have said you have to jump solenoid on starter if you need i'll try to get a picture of mine
Everett Hill 2134 STK, SS
Everett Hill is offline   Reply With Quote
Old 07-29-2014, 01:01 PM   #8
Lee Sherburn
I guess I am confused with hooking up my powermaster as the tilton starter I removed only has the battery cable hooked to it. So what do I hook the terminal marked switch on the selinoid to? Guess a picture or drawing would help.
#4 on the instruction sheet that came with it plainly says( ATTACH BATTERY CABLE AND SWITCH WIRE. The switch wire should be capable of handling 25A. Switch wire to where?
Thanks Lee
Old 07-29-2014, 01:49 PM   #9
69Cobra
Liked 2 Times in 2 Posts
You should have your main starter cable that runs from the solenoid down to the starter. That goes to the main post for the starter motor but then you should also have another smaller terminal for the starter solenoid that's on the starter itself. Just take a #10 size wire with a ringed terminal end on it and jumper between the two post. Now when you hit the key and it pulls in the factory solenoid on the inner fender well it will also energize the solenoid at the starter and pull the starter in to spin the motor.
Hope that helps.
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 07-29-2014, 01:53 PM   #10
Sean Marconette
Sean Marconette's Avatar
Liked 281 Times in 78 Posts
If you have a remote solenoid, the new starter also has a solenoid. The S terminal is the solenoid on the starter. Add a jumper wire from the S terminal on the starter to the terminal on the starter that the power cable is on. This will be like placing a screwdriver across the start and power terminals on a remote starter solenoid, but will be permanent.
Sean
Sean Marconette
84 Mustang
5060 SS/N
