Old 07-14-2014, 12:08 PM   #1
Liked 10,706 Times in 2,229 Posts
Default Comp Roller Rockers
Checked a new set of rockers for the stocker and the lift only changed .002'' at the valve. I checked all rockers in the same position on one head. Lift at the valve could still vary due to stand or valve placement in relation to the fulcrum point, and pushrod length or lobe lift difference.
Old 07-14-2014, 02:37 PM   #2
SSDiv6
Liked 1,583 Times in 582 Posts
Default Re: Comp Roller Rockers
Larry, did it change + or -?
Any variation on all the possibilities you mentioned, will affect the reading.
For your application, my preference would have been T&D P/N 8200 or Harlan Sharp P/N S70015K.
Old 07-14-2014, 05:09 PM   #3
Checked .481'' +/- .001
Old 07-15-2014, 09:24 AM   #4
SSDiv6
I assume the 0.481" is for the exhaust lift; what does it check at the intake?
The spec sheet calls for 0.467"/0.483", so at 0.481", +/- 0.001 is quite close.
Old 07-15-2014, 11:48 AM   #5
I try to get all lifts to be -.001'' to a max of -.004. Everyone else in the class has over .500'' lift so I don't want to give up anything.
Old 07-15-2014, 12:38 PM   #6
SSDiv6
Agree, smart way to do it.
