Old 07-02-2014, 11:48 AM   #1
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Any Tips for Installing a Trans?
I take delivery of a C4 from TCI today and was wondering if anyone has tips for installing a trans in a car that still has the engine on the stand.
The car is on jack stands with no rear end at the time being. I have a trans adapter for a floor jack, so rolling it under the car from behind is possible. Should I do this or wait until the engine and rear end are complete and bolt it up and install the trans and motor as a unit? I don't have access to a lift and my stands max out at around 20 inches.
It's going on a SBF 302 in a 68 Mustang coupe.
I need to be able to do all of this single handed.
Thanks ahead of time.
Dale
Dale Shearon
68 Mustang 6394
Old 07-02-2014, 12:03 PM   #2
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Any Tips for Installing a Trans?
If it were me, I'd install the trans last.
* Putting it in first, you'd need to keep it supported up front, which may interfere with the engine installation.
* Installing the engine/trans already assembled seems like a pain. I tried installing and/or removing that way a very long time ago and never considered trying it again. But I have heard of some people doing that.
LOCOMOTION Racing
Old 07-02-2014, 01:33 PM   #3
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Any Tips for Installing a Trans?
Easily accomplished by yourself if you use one of these... http://www.oreillyauto.com/site/c/de...0767&ppt=C1944
Another... http://www.northerntool.com/shop/too...ct_19979_19979 One without a crank handle will be slower, but the handle sometimes becomes an impediment at extreme angles...this one would void that scenario using a ratchet/socket.
Rich Taylor
I/SA - 321
Old 07-02-2014, 02:18 PM   #4
Mark Ugrich
Liked 71 Times in 38 Posts
I'd put the trans in last. You might want to mock up the engine and transmission.Check clearances and converter to flywheel fitment.
Old 07-02-2014, 02:29 PM   #5
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: Any Tips for Installing a Trans?
* I agree with Myron & Mark, put the trans in last ... Keep it simple when you are alone , don't over-load anything you can't handle yourself ???
Get everything else in & then put the trans in , when you can handle it alone from under the car... But smart & you won't get hurt or cost you more $$$$$$$... Good Luck with the project ...
Dave Ribeiro 1033 STK
Old 07-02-2014, 02:57 PM   #6
HandOverFist
A motor with trans attached overloads nothing unless you use defective equipment. You could not "catch" a falling trans or motor by yourself regardless of the situation...use your head and trust the equipment.
Rich Taylor
I/SA - 321
