My 68 charger has issues hooking with transbrake, foot brake it hooks fine with a 1.50 60ft . The car weighs 3350 with driver. 440 ci, 688hp,620 Ftlbs, 5000 stall,4.56 gear, 727. Any thoughts of what is happening. In the video I launch at 3600. The ladder bars are parallel with the ground. I have single adj qa1 in the rear set on 2 clicks from full soft and dbl adjustables Qa1 in the front set on 2 clicks rebound, 10 clicks comp. I haven't tried tightening up rear shocks yet. I would like to here some opinions thanks. [ame]http://m.youtube.com/watch?v=WBGRDKZsQsw[/ame]
Here's another vid in 500fps. [ame]http://m.youtube.com/watch?v=hNgRpwuaOHU[/ame]
Liked 33 Times in 16 Posts
Looks like it's bouncing to me.
Rich Taylor I/SA - 321 |
Liked 11,033 Times in 2,268 Posts
Make sure the rear shocks are long enough in extension so they don't lift the wheels at full rise.
Liked 3,263 Times in 990 Posts
What Larry said, plus I'd be curious if you've moved the front Ladder Bar pivot point downward and tried that. Moving the CG forward might help transfer the weight better. With that much power you should be in the 1:30's sixty foot.
Liked 287 Times in 88 Posts
68…Looks like Saskatoon and you've got Bernie watching over you. Are your 60's consistent with the footbrake? Do you know the weight bias of your car? MB.
