I was curious as to how other fellow racers have installed a heater in the differentials.
Of course an obvious option is on the exterior of the housing...but does the heat actually penetrate the thick iron of the center section? Is putting the pad inside the center section a good option with all the moving parts inside? or would a block heater type element be the way to go? The differential for my application is a 12 bolt chevy with a LPW cover if that matters at all
Dion Hildebrandt 6009 STK H/SA |
Liked 64 Times in 11 Posts
I just slide a 500w light under the rear diff. About 30 min and she is about as hot as I dare get it. I only do this for class eliminations. What's it worth? Not as much as you hope!
I use a immersion cartridge heater screwed into the drain plug
http://www.mcmaster.com/#cartridge-heaters/=qofs8g
Bill Edgeworth 6471 STK |
Yeah I realize that, just dreaming out loud as I was servicing my differential. Had a discussion about lubrications the other day and just got the brain matter flowing is all. At any rate something is better than nothing...right?
Liked 4 Times in 3 Posts
have heated the gear oil several times never saw a thing out of it
so we just use the good gear oil and that does the trick
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK Moneymaker Racing LaPorte Indiana 219-861-1214 www.moneymakerracing.net |
My friend's recently sold Pro Stocker had an oil tank/pan heater screwed into a welded-in bung in the back of the rear end housing. The cord was zip-tied to the left wheelie bar so it was easy to plug in to warm up the gear lube before each round. I thought about adding one to mine. Easy to weld the bung to the rear cover of my 12 bolt. Just use it for tough heads ups, class, etc.
Heard of guys running Dexron ATF for gear lube (One guy said "all the time"). Not sure about that deal. I'm too old to weld up the gears in the lights and go for a ride. LOL
Ed Wright 4156 SS/JA Last edited by Ed Wright; 02-13-2014 at 04:43 PM. |
#7 | |
Liked 462 Times in 92 Posts
Ed' I have used atf a lot in slow cars and never hurt the gears.
Bob Bender 144 O/SA 2010-2012 National Record Holder |
#8 | |
#9 | |
Liked 684 Times in 289 Posts
It ran E/SM at the time (old format) and right on the record. It was losing nearly .10 each pass. After 3 qualifying attempts, we could hardly push the car. Tore it up pretty good... Used gear oil from then on. Last edited by Mike Jones; 02-13-2014 at 10:46 PM. |
Liked 280 Times in 139 Posts
Run Joe Gibbs qualifying oil,you don't need a heater with it. gsa612
