Old 02-02-2014, 10:41 AM   #1
terry1
Liked 24 Times in 13 Posts
Smile Another weight question.
I may be adding/adjusting weight to my car (1978 I/S Camaro ). From the "weight" threads I reviewed, the common location seems to be over the rear axle.
My question is, would you divide up the weight to go over each side equally, or all weight on one side, or more weight on one side than the other?I have a weight box to "fine tune" my weight for various scales.
terry1 is offline   Reply With Quote
Old 02-02-2014, 11:01 AM   #2
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Another weight question.
terry - At your hp levels I don't think it will make much difference where the weight is placed. Most will be centered or favoring the passenger side.
Rich Taylor
I/SA - 321
Old 02-02-2014, 11:10 AM   #3
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
If you can get access to a set of scales that weigh the corners of your car, you will be much better equipped to decide where the weight "needs" to be........AND be prepared to make adjustments based upon actual performance.
Dave Turner
SS/GT #1153
Old 02-03-2014, 12:12 AM   #4
Jared Jordan
Liked 547 Times in 121 Posts
Send a message via AIM to Jared Jordan
Unless you're having wheelstand issues, you can't go wrong with a big bar of lead as far back over the rear bumper as you can get it. More = better.
Jared Jordan
9 B/SA
2024 Jeg's D7 All Star - Stock
Jared Jordan is offline   Reply With Quote
