Old 01-24-2014, 12:59 PM   #1
rod
Liked 20 Times in 15 Posts
Default U-joint girdle ?
your thoughts on the aluminum rear U-joint caps/girdles which replace the U-bolts. are they good, bad, pain in the a** or ?
thanks Rod in AZ
rod is offline   Reply With Quote
Old 01-24-2014, 01:46 PM   #2
Jim Kaekel
Liked 539 Times in 112 Posts
Default Re: U-joint girdle ?
I wouldn't waste your money on those aluminum girdles. I had a set 30 years ago when I was young and not so smart. If you've got 1310 series U-joints/straps and need to upgrade, change over to 1350 series stuff. Mark Williams is the best. That my .02.
Jim Kaekel 3836 STK
Old 01-24-2014, 07:46 PM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: U-joint girdle ?
My upgrade from OEM style stuff included Spicer solid joints and a steel billet rear end yoke with u-bolts. Good variety of joint choices for Mopars and I'm sure there are plenty for other brands, especially GM.
LOCOMOTION Racing
Old 01-25-2014, 01:55 AM   #4
Adger Smith
Liked 880 Times in 311 Posts
Back "In the Day" when you couldn't upgrade to 1350 it helped with U-joint life on my Stick Shift stocker. don't use them now with the 1350 stuff. Just don't see any problems with the current 1350, except they are heavier.
Adger Smith (Former SS)
Old 01-25-2014, 08:44 PM   #5
Dirk Olson
Liked 172 Times in 46 Posts
I agree with Jim, don't waste your money buy MW and forget it.
Dirk
Dirk Olson 5036 STK
Dirk Olson is offline   Reply With Quote
Old 01-25-2014, 09:19 PM   #6
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
I've got a new set for a mopar if you can us 'em, I chickened out and bought a good yoke + ubolts for my rambler...
Old 01-26-2014, 03:48 PM   #7
Joe Martens
Joe Martens's Avatar
Liked 198 Times in 71 Posts
Can't go wrong with Mark Williams!
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
