Old 12-25-2013, 06:40 PM   #1
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default 60' times
How does one figure 60' times on a car that carries the front wheels past the beam?
Rich Taylor
I/SA - 321
Old 12-25-2013, 07:09 PM   #2
Tar Heel
Guest
Posts: n/a
Default Re: 60' times
I'm not sure exactly if I understand the question but aren't the timers tripped in that case by the rear wheels?
Scott
Old 12-25-2013, 07:24 PM   #3
HandOverFist
Yes, but in that case there is no true indicator as to what the car actually did. I was wondering if there might be some formula to convert the bogus number to a relatively accurate one...maybe subtract the wheelbase?
Rich Taylor
I/SA - 321
Old 12-25-2013, 08:16 PM   #4
countrypuppy4865
countrypuppy4865's Avatar
Liked 229 Times in 71 Posts
Scott, if the car lands as it is getting to the 60ft clocks it can be tripped by the middle of the car or anything lower than that (collector for example).
I don't think there would be any way to accurately measure the time.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 12-25-2013, 08:29 PM   #5
HandOverFist
I know there are a lot of cars out there that do this regularly...wonder if they just go off the long (wrong) numbers?
Rich Taylor
I/SA - 321
Old 12-25-2013, 10:11 PM   #6
Darrin Christen
Darrin Christen's Avatar
They probably just look at the 330' numbers instead of the 60'
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
Old 12-25-2013, 09:06 PM   #7
HP HUNTER
Liked 373 Times in 129 Posts
On Johns 67 Chevelle the best 60 was 1.28, on the rear wheels, the best ever 1320 ET was on the rear wheels with a 1.40.
Old 12-25-2013, 09:41 PM   #8
HandOverFist
Are you trying to say he tripped the beams with the back tires in both instances?
Rich Taylor
I/SA - 321
Old 12-25-2013, 10:03 PM   #9
Neil Smedley
Liked 22 Times in 7 Posts
when your front tires leave the beams, it starts the clocks.........does not matter if they roll out or go sky high
Neil Smedley is offline   Reply With Quote
Old 12-25-2013, 10:20 PM   #10
HandOverFist
But it does matter which wheels trip the 60' beam...
Rich Taylor
I/SA - 321
