Old 09-16-2013, 09:27 AM   #1
Rusty Davenport
Liked 101 Times in 27 Posts
Question Mopar master cylinder---disc/drum application
Mopar master cylinder has a 9/16 outlet at the front and a 1/2 outlet closer to the firewall.......can any of you brake Einsteins settle the arguement on which outlet goes to the rear drum and which goes to front disc ??? Thanks for any help.
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 09-16-2013, 09:50 AM   #2
Rsmith38
Liked 28 Times in 15 Posts
Default Re: Mopar master cylinder---disc/drum application
My MOPAR PERFORMANCE cyl (there are at least 2 - diff bore diameters) has metric fittings. I have used both diameters and with rear drums, then with Grand Cherokee rear disks. with no discernable difference. mine has front brakes on the front port (with line lock).
Rsmith38 is offline   Reply With Quote
Old 09-16-2013, 10:00 AM   #3
Rusty Davenport
I was asking about port sizes and placement, bore size is not the issue, thanks for your help
Old 09-16-2013, 10:44 AM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
The outlet closest to the pushrod is typicaly used for the front brakes on most drum / disc brake applications.
The front piston has slightly less volume than the rear ,but both develoup the same pressure.
In race applications I've seen them plumbed both ways and work, but I always do mine as I said above.
Old 09-17-2013, 06:43 AM   #5
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
http://www.swracecars.com/Files/Brak...g%2094-107.pdf
***Check the first NOTE.
Old 09-17-2013, 09:05 AM   #6
SPS
Liked 3 Times in 2 Posts
We recommend front cylinder to the back and back to the front brakes in the kits we send out.
As Tom says, I too have seen them both ways with equal results.
FJ
Oh yes, the masters come with fittings that take standard 3/16 lines.
SPS is offline   Reply With Quote
