Liked 107 Times in 35 Posts
Anybody use the Resbond products (907gf, 940, 940ht) to fill them or does everybody just melt aluminum and pour? Any other high temp epoxy used? Pontiac v8 application. Thanks, Ron.
Liked 96 Times in 23 Posts
Aluminum and I pour from the intake side.
Adam Strang 1018 STK |
Liked 12 Times in 6 Posts
Mine have been filled with aluminum, poured in from the combustion chamber. I used to just have them blocked off with aluminum plates on the intake side of the head. My 71 HO intake is aluminum and does not have the heat cross over as part of the intake.
I am curious if filling the head with aluminum will result in any power gains now that the two middle cylinders are not connected anymore. Any thoughts?? Scott |
#4 | |
#5 | |
Liked 282 Times in 103 Posts
Liked 319 Times in 108 Posts
Ron,
I use zinc alloy get from Mc Master Carr supply ,it's the same thing Mondello use to sell. I melt enough into a steel cup I made from tubing and flat bar w/flat bar long enough to also be handle to pick up and pour with,I usaully block @ intake side and pour from bowl side have to use some sort of funnel some times. The zinc will probaly out last the heads. Mike Taylor 3601 |
#7 | |
Liked 327 Times in 121 Posts
Considering that all the accepted Edelbrock aluminum heads that I`ve seen have no crossover provision at all, thus no "cave" in the port, wouldn`t it be nice if NHRA allowed factory heads be completely filled too?
#9 | |
This is what I found on McMaster-Carr's website: http://www.mcmaster.com/#zinc-alloys/=outleo Great info guys! Thank you |
I usaully buy the 4 1/2 lbs. bar 9069K2. depending on what type of heads you are working sbc can do 2-3 sets.
Have also filled intakes that are cracked in heat cross over area,just fill it up does'nt matter then. Mike Taylor 3601 |
