Old 01-13-2013, 02:58 PM   #1
KURT GROSS
Default Electric Fan Choices
Need to puchase an electric fan and would like everyone's opinion on what brands/models are good or bad. Is for a 1970 Nova with stock radiator. Also does running a relay make a big difference? I control it manually through a switch in a Painless wiring panel.
Thanks
Kurt
2001 Division 6 S/ST Champion
2002 Jegs Allstar
2010 Woodburn Dragstrip S/P Track Champion
KURT GROSS is offline   Reply With Quote
Old 01-13-2013, 03:36 PM   #2
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
Default Re: Electric Fan Choices
I just bought one of these. 3000 CFM
http://www.summitracing.com/parts/hfm-zfb16s
http://www.summitracing.com/parts/hfm-zfpl2
68 Chevy11 327 F/S
Bob Gullett is online now   Reply With Quote
Old 01-13-2013, 04:09 PM   #3
Ed Wright
Ed Wright's Avatar
Kurt, for sure use a relay.
Ed Wright 4156 SS/JA
Old 01-13-2013, 05:04 PM   #4
Wade Mahaffey
Wade Mahaffey's Avatar
Liked 18 Times in 8 Posts
Here is what I use, the shroud is the most important component. If you place a fan of the typical style (black plastic screen housing with wire ties thru the radiator type) the fan pulls/cools only the footprint of the fan circle. That is about half of the radiator, you can do the math on it A) find sq. in. of the rad L X H. B) Now find the sq.in. of the round fan: Dia sq X .7854 Example for 16" fan: 16 X 16 X .7854 = 201.06. That normally will show that only about half of the radiator has fan advantage. With a custom built shroud, you will draw air thru 100% of the core and cool in half the time. Normally with an electric water pump, a car running at 200+ can turn the engine off...run the fan and pump...and cool to 160 in 2-3 minutes....now understand that's using the Flex-a-lite 15 inch black majic fan rated @3300 CFMs and a custom shroud.
Wade Mahaffey
Wade Mahaffey is offline   Reply With Quote
Old 01-13-2013, 06:13 PM   #5
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Chevy HHR. costs under 100 bucks and comes w a shroud. Easy install on a 68 Chevelle. should be easy on Nova then if its a cross flow. We used painless kit.
chris ok is offline   Reply With Quote
Old 01-13-2013, 06:40 PM   #6
Northern Radiator makes a lot of electric fan and shroud kits, with relays and wiring, as well as various accessories.
