Old 11-08-2012, 12:25 AM   #1
GTX JOHN
Default Mopar Ball Joints
I had a upper Ball Joint fail on Demon in Pomona today.
Are there any better quality Ball joints available than
the regular Auto parts stuff?
I use Energy Bushings
in the front end but regular replacement Ball Joints I have
1972 Small hole Drum brake setup. Does anybody make a spacer
to us larger disc brake spindles in early A arm/Ball Joint?
Old 11-08-2012, 01:05 AM   #2
70AARCuda
Liked 11 Times in 6 Posts
Default Re: Mopar Ball Joints
doctordiff@gmail.com
(406)883-4772 10-6 Mountain Time, M-F
http://www.ebay.com/itm/67-72-Mopar-...99e6c2&vxp=mtr
Is this what you are looking for?
Tony
70AARCuda is offline   Reply With Quote
Old 11-10-2012, 12:58 PM   #3
magnumv8
The old school front end shop fix for this is pretty simple.....all you need to do is with a small hammer take and tap the ball joint flange in the A arm reducing it's diameter to the point where the bottom of the new ball joint still slips in but the threaded portion does not.....screw in the new ball til it seats then put a couple small tack welds on it and you are done......
D L Rambo STK 1300
magnumv8 is offline   Reply With Quote
Old 11-10-2012, 07:50 PM   #4
Michael K
Liked 62 Times in 17 Posts
I used Moog ball joints on my 68 A-Body that has 73-76 front suspension.
The paperwork Moog supplied said "thread ball joint squarely into control arm until shoulder of ball joint is firmly seated against the arm. If torque required to seat the housing is less than 125 ft-lbs, the control arm must be replaced."
I can't remember what mine checked at, but well over 125 ft-lbs.
Michael K is offline   Reply With Quote
Old 11-10-2012, 09:06 PM   #5
Run to Rund
Liked 56 Times in 29 Posts
I would rather not weld on heat-treated ball joint housings. I'd look into red Loctite on the threads, and welding a strap across the joint onto the A arm.
Old 11-11-2012, 04:26 PM   #6
GTX JOHN
Thanks for all the Excellent Advise.....I think I will buy the
new reproduction stuff When you consider the lower joints
alone are 50 each it makes to package not that bad!
Thanks Again!!
Old 11-08-2012, 10:13 AM   #7
Mark Howes
Liked 80 Times in 28 Posts
I also had a failure with my SS/JA '71 Duster this fall at Epping. Luckily nothing serious came of it.
I was looking at welding them in place but this looks like a good idea. Thanks for the link!
Mark Howes is offline   Reply With Quote
Old 11-08-2012, 12:09 PM   #8
Philip Saran
Liked 14 Times in 11 Posts
John,
I know you need a fix today..........but later maybe it's time to upgrade to
either 73-76 A-body disc brakes with the bigger ball joints or aftermarket
disc brakes?
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 11-08-2012, 12:27 PM   #9
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
Where are they breaking at?
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 11-08-2012, 01:27 PM   #10
Todd Boyer
Liked 6 Times in 5 Posts
Mark, the above kit looks like a good idea for adapting the '73-'76 -larger/beefier/BUT heavier- knuckles to the early ball joints, but you'd still be using the same early (small) ball joint and control arm. If it's the early ball joint and control arm that is the issue, this kit isn't gonna be of much help.
Afco makes low friction all joints, not sure about 'better quality' as John asked for, but likely are.
http://www.afcoracing.com/#
