Old 10-09-2012, 06:31 AM   #1
RAGIDY57
Default Front end advice 68 camaro
HI, I know i dont post here but i figure i could get the best advice for what i want to know here.
I have a 80s early 90s style back half bracket car. I am trying to get the car to work better on bad tracks. If the prep is Great the car is Great. I feel like the front end is real tight. I know the car weights about 2550 without me in it.
The front end of the car is pretty much stock. A arm, drum brakes, steering box. car is currently a steel headed sbc.I do have QA1 single adjustable shocks and stock springs. I would like to put the tubular a arms on and disc brakes. I really need to upgrade the front end but money is an object and looking for the best bang for the buck .
So what parts and pieces to you suggest?
Main questions are what to choose between the QA1 coil over conversion kit and the santhuff.
Which Disc brakes to go with? rear are drums.
Should i change bushings and add a front end kit.
I want to cut the crossmember under the motor out and add a motor plate. Mainly so i can take the oil pan off while the motor is in the car.
Thanks
Tee
RAGIDY57 is offline   Reply With Quote
Old 10-10-2012, 10:57 AM   #2
tj310
Default Re: Front end advice 68 camaro
I wouldn't bother with the coilovers, sure they look cool on a tube chassis but that ain't what you got.
Same with the tubular control arms they may be a few ounce's lighter but they don't make any difference to the geometry of the suspension .
How much weight on the front ? ---Trevor
Old 10-11-2012, 12:58 AM   #3
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
Heres my recipie...i had stock but brand new moog bushings in factory control arms when i first built the car but i recently changed to global west bushings. Very difficult to inatall and take a tonne of massaging to make them work smooth. The lowers were a breeze....the uppers collapse when they are pressed in and need to be honed out to operate smoothly through the travel. I dont think there was any et improvment from my moog bushings and the GW but i think being more solid helps hold the alignment better and it is a bit smoother to drive. So all in all its a good deal. Camaros like to be in the weeds in the front for some.reason.....maybe thats a small tire thing but i guess it cant hurt in a big tire back half car. Mine is so low in the front i had to go to a 2.25 offset wheel in the front to stop the tires from hitting the fenders. I have 5.5-6 inchest of front end travel which is pretty good for a stock control arm camaro. Moroso 47140 springs with one coil cut off gets it where it needs to be....bump stops in the lower arms for sure so you dont bottom the shock out and bend anything. Wilwood dynalite brakes are the best barr none....they go together very easy and they work great. Alignment....1/16 to 1/8 to max depending on how old your front end components are....new you can probably hug the 1/16 toe i would think and as much positive caster as possible. Ohh and the avco low friction.ball.joints are a good investment too. Very slick. And i also use calvert 90/10 shocks in the front. They seem to.work.ok.as well. I had comp.engineering 3 ways and liked them too. Im sure there is a better way to build a front end but this is a budget minded way to do it without getting into 3000 dollars in shocks and springs for a minimal gain. My car bounces at least twice when.it come down from the wheelstand but it never gets out of shape and always sets itself down straight. The two bounces keep me awake....hahahaha
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 10-11-2012, 01:19 AM   #4
Liked 1,826 Times in 414 Posts
Global West Del-A-Lum bushings, Moog shafts, Moog long upper ball joints, Moog lower ball joints (both ball joints should be low friction), Strange or Wilwood bolt on disc brakes, stock small block no air front springs with 1 coil removed, or Moroso trick springs. Santhuff shocks. Cut all but 1/4" of rubber off of the travel stop under the upper control arm. Or take it all the way out. Cut all but 1/4" of rubber off of the lower bump stop.
You have to notch the crossmember, you cannot take it out completely, or the front end will flop around. There has to be something tying both sides together besides the engine if you run the stock front subframe and basically stock suspension.
Put your weight in the front seat, jack the car up 1-1/2" in the front, and align the front end there. As much positive caster as you can get (we've run 7 degrees) zero camber, and 1/16" toe in.
If you want to see how that all works, here you go:
Old 10-11-2012, 10:33 PM   #5
chris tinberg
Tee , i see you live in Rustburg Va. you are next door to the best front end guy in the country Gary Wisecarver give him a call 434-332-4511 he will solve any front end problem you have and you WILL NOT meet a nicer guy. he has done many 67-69 camaro's front ends including the one we had .and tell him the Tinbergs referred you . good luck chris
chris tinberg is offline   Reply With Quote
Old 10-13-2012, 05:37 AM   #6
RAGIDY57
Thanks Guys. I know Gary well. I just didn't think he would want to see lil ole me when he has alot more higher in cars to deal with.
If i can remember ill post a youtube link of the car when i get a chance at home. Dang Ole work computers block out the good stuff.
I am going to email VMP and see if the scales are open next weekend for the Mac Race. That way i can have a good set of numbers to go buy when ordering stuff.
Old 10-15-2012, 02:34 AM   #7
RAGIDY57
Alan you wouldnt have part numbers to the TRW-Moog parts would you...or even everything. If i go this route i would want to make sure i buy what i need the first time around.
thanks
Old 10-16-2012, 02:22 AM   #8
RAGIDY57
Also is there any advantages in going with a 2in drop spindle. My car does have a good stance as is.
Old 10-21-2012, 08:27 PM   #9
RAGIDY57
I just wanted to make sure scaling method is correct.
With front tires on the scales it weighs 1620
Car all the way on scales its 2925
With rear tires on scares its 1305
I'm a big boy lol but without me its 2535
