Old 09-10-2012, 10:58 PM   #1
brent flynn
brent flynn's Avatar
Default vega steering box...
Who is running a vega steering box on their '68 Camaro/Firebird? and will the one out of jegs work ok? Will i need the pitman arm, as well? THanks!
2 Products View All
555-60750
Vega Steering Box
22:1 Steering Ratio
5/8"-36 Spline Input Shaft
Intended for use in vehicles weighing 2500 lbs. or less
More info on JEGS Performance Products 60750
$249.99
Ships
Today
555-60752
Vega Pitman Arm
6" Center to Center
Large End: 1" Dia. x 36 Spline
Small End: 0.600" Dia. with 4° Tapper
View this item
Old 09-11-2012, 06:10 PM   #2
brent flynn
Default Re: vega steering box...
207 look sees and no answers? hehe... somebody help a dude out...hehe
I want to buy one, just want to make sure its a direct swap...Thanks!
Old 09-11-2012, 06:17 PM   #3
L78 Nova
L78 Nova's Avatar
Liked 23 Times in 13 Posts
For what I know...spline size on the Vega box is different. You will have to fab a pitman arm. Box is smaller so the rag joint will come up short too so you would have to fab something there as well.
Gary
L78 Nova is offline   Reply With Quote
Old 09-11-2012, 06:31 PM   #4
Tod Lane
Tod Lane's Avatar
Liked 2 Times in 2 Posts
Don't think that box is rated for the weight of that Camaro...
An S10 box may be a better option.
Tod Lane
Swartz & Lane 66 Nova
Swartz & Lane 79 H/CM Trans Am
Tod Lane is offline   Reply With Quote
Old 09-11-2012, 06:58 PM   #5
brent flynn
i figured i'd need the pitman arm... i wasnt sure if it was basically a direct swap... sounds more trouble than its worth... i figured it'd be ok to be used on a drag car... was lookin for more header clearance...
Old 09-11-2012, 07:23 PM   #6
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Hi
I was going to try one of those but was talked out of it by a fellow racer who had one fail
( brake off the frame)
and it caused him to crash his car in to the wall.
I don't think it was worth it.
Just my 2 Penny's worth..
MEXJOE is offline   Reply With Quote
Old 09-11-2012, 09:42 PM   #7
brent flynn
Originally Posted by MEXJOE View Post
Hi
Well, i doubt thats what i'll do... i probably stick with the camaro box that i have... THe headers i have are pretty tight(hedman Huslers), but gonna switch to Mad Dogs, which i believe will fit better... Huslers arent legal for stock(plates)...
Old 09-11-2012, 10:28 PM   #8
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
I would love to hear more about this S 10 manual steering and a pitman arm and any info you can pass on boxin a first gen F body. This is a 1967 Camaro I am working on. We are starting w a power box n pump and looking to remove it.
Car in body shop n will be home prob sooner then later.
Chris.
chris ok is offline   Reply With Quote
