Old 08-13-2012, 09:35 AM   #1
Brian Hummell
Unhappy Hey Pontiac gods
stupid question Pontiac 1976 350 hrmonic balancer what should it look like. on my GP that was givin to me by my late father. and i did not build engine. the balancer looks like outer ring is missing and appears it was assmbled that way.every thing i have looked at on net is not the same.it appears that only snout that pulley bolts to is there.i had not drove it much, but because of a bad car crash i had to use it .
Brian Hummell STK 3108
1970 monte carlo current I/SA
Brian Hummell is offline   Reply With Quote
Old 08-13-2012, 11:12 AM   #2
Doug Domm
Liked 85 Times in 22 Posts
Default Re: Hey Pontiac gods
I have seen a number of those Pontiac 350's with what looks more like a hub than a balancer. I have 2 of those motors and both have that balancer. On both of them the factory timing indicator cast into the cover is cast right over top of that hub so I doubt any outer ring. But I'm sure a Pontiac builder will come on here and give you an absolute. Doug
Doug Domm is offline   Reply With Quote
Old 08-13-2012, 05:17 PM   #3
Brian Hummell
Thanks Doug. Timing tab is tin .. I am pulling motor has noise in bottom end . just need to know if whats on it is correct if not. it may be what caused problem. Brian
Old 08-13-2012, 10:28 PM   #4
Brian ,You can put a std. size dampener on it as long as it's for a 350-455. They are zero balanced. Make sure it's not for a 265-301.
Then use an early cover .The covers are being repop-ed now.
I doubt what you have is causing any problem though.
Old 08-14-2012, 04:34 PM   #5
Brian Hummell
thank Mark
here is what is in car now. tell me this dose not look right.
look at third photo on this ebay listing. that is all i have found in parts store look up. engine in car is supposed to be a 350.
http://www.ebay.com/itm/230835027877...84.m1423.l2649
like i said i did not build this motor.
Name:	balancer 350 pontiac.jpg
Old 08-14-2012, 09:20 PM   #6
Originally Posted by Brian Hummell View Post
thank Mark
Look at the block, right around where the dipstick tube crosses it, under the head. It will have the displacement cast into it...(both sides)
What is the two digit number on top of the center exh. ports?
That motor probably has the smaller dia. hub for locating the flexplate , too.
I never heard as to why they made some 350's that way, but it is not all that rare.
Hey, why does the oil pan appear to be bare metal?
