Liked 19 Times in 7 Posts
Doing an quick once over on a 65 GTO 389 tri power and I have a question. I have converted the points distrib over to a Crane XR1 electronic ignition and their recomended coil. So no more points/condensor/bla bla bla. I just recieved my new engine wiring harness and my question is this. Should I remove the resistance wire that powers the coil right now and replace it with a normal wire? Seems like this right thing to do but im not 100% sure. Before I start un-taping the new harness I would really appriciate some input. Thanks in advance!!
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A |
#2 | |
Liked 459 Times in 90 Posts
Yes.......you need a full 12 volts for the new unit. Sorry just like big letters.
Bob Bender 144 O/SA 2010-2012 National Record Holder |
HAHAHA....BIG car BIG letters. I unwrapped the new harness today....took the connector out of the new plug and soldered a new wire in place of the resistance wire...cant even tell. So now I should be able to just hook up the new wire to the coil with no balast resistor or anything correct??? The Crane coil that came with the XR1 conversion did come with a balast resistor but im hoping I dont have to run it. I was born in 1980 so points and all this stuff is French to me....im a part of the HEI generation....LOL
Liked 544 Times in 213 Posts
Old cars with points had 2 wires going to the positve side of the coil.
One wire was thru a resistor or resistor wire. It would supply about half voltage to the points to reduce arcing. That would be about 6 or 7 volts The other wire was from the starter solinoid. It supplied the full 12 volts during cranking only. Made for a stronger spark at the slower cranking speed. Points were pretty troublesome items in their day. They often needed service. I replaced, cleaned, adjusted a heck of a lot of them...... I wish I had a '65 GTO to play with.......Loved them cars.....Still do....Tri-Power, 4 speed.......Black bucket seats.......Red hardtop....Exhaust splitters.... I had a mint '67......but always wanted a '64 or '65
