Liked 22 Times in 22 Posts
Can you use the same rings when you do a quick ball hone before reasembly? Only three pulls on motor. What grit ball hone?
don,t have one |
Liked 1,952 Times in 439 Posts
Randy, yes, you can do that, if the rings do not have a problem.
The best ball hone you'll find available quickly would be a 320 grit, you shouldn't need but a few passes, unless the cylinders are really screwed up. Brush Research makes the best ball hones, that's all I ever use, with their hone oil. I use a special version that is 1000 grit levigated aluminum to finish cylinders. I do have a 320 grit I use first on a "freshen up".
Alan Roehrich 212A G/S |
Thanks Allen. They shoudn't be in bad shape, I did the 14 gegree motor for a tractor puller, and at high rpm it blew the O ring on the filter, and I'm changing bearings, and thought I'd hit it quick. I've heard it doesn't hurt, and usually helps, so I thought I'd try it. It has .043 and 1.5 napier, and 3 mm. Is 320 OK?
don,t have one |
Do you torque plate before you hone with a ball?
don,t have one |
Ball hones are really for "surface conditioning", a 320 grit or finer ball hone really won't remove metal, unless you just hone on the block all day. You shouldn't need a torque plate, I do not use one when I ball hone.
Thank you Allen. You have been most helpful.
don,t have one |
