Liked 232 Times in 108 Posts
Getting ready to get my car out (I hope). I know I'll need taller valve covers because of roller rockers. Like the look of the fabricated one's but, wanted the pro's and con's of them. Noticed on BBC there is two types available. 1 with short screws and 1 with long screws. Price seems to be ALL over the place too. Recommendations?
Liked 1,954 Times in 440 Posts
I don't care for the fabricated valve covers. You simply pay a ton of money to look like the Pro Stock guys. Half of them hold oil in the rail and make a mess when you take them off. We have a set on the Super Stock engine, I get the urge to find a trash can for them every time I pull them off.
I'd just as soon have a decent set of die cast aluminum valve covers, they don't warp, and they don't leak. The only draw back, if it is one, is a couple of pounds of weight. If weight is a problem, stamped steel or stamped aluminum, with load spreaders, is the way to go. Just throw the load spreaders away every year or so, because they make them out of cheap steel, and then when they chrome them, they bake the heat treat right out of them, so they end up soft. It'd be great is some one would make some load spreaders out of spring steel or cold rolled steel, and just coat them, cad plate them, or iridite them, so they'd stay real stiff.
Alan Roehrich 212A G/S |
#3 | |
Jeff Lee 7494 D/S '70 AMX |
Jeff, that is indeed correct. The problem is that they work well for a small block Chevy, and some other engines, but they don't work well on most big block Chevy valve covers.
Liked 784 Times in 196 Posts
They do work on stamped steel valve covers on the bottom and that's where most of leakage problems occur. The best stock stamped valve covers came on marine engines; heavier guage and precision fit. They do not warp, clear most rocker arms including T&D, Jesel. They's just not glamorous enough for the up to the fence people.
Liked 694 Times in 206 Posts
Terry I got a couple pair of tall stamped steel chrome moroso valve covers no baffles and has grommets in place both pair are nice if your interested let me know.
#7 | |
Chad Rhodes 2113 I/SA |
Chad,
@#!$ forgot about that. Grrr, ain't been nothing that would fit out of the box on these fiberglass cars. After doing a little research, No one pays to run thier valve covers except MOPAR. How much trouble you think it would be to modify a set of Mopars to fit a BBC? Alan, Good point about oil laying in them. Need to get oil back to bottom ASAP. Last edited by Terry Cain; 06-04-2012 at 04:33 PM. Reason: added |
#9 | |
OK Chad,
How do you know? |
