Old 04-30-2012, 06:01 PM   #1
art leong
Default Slick size differences?
How much difference is okay as far as circumference of a slick. I just measured mine and they are 1/2 to 3/4 inch different in circumference (mounted on the wheel same air pressure).
Is this to much or is it acceptable?
Art Leong 2095 SS
Old 04-30-2012, 07:14 PM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: Slick size differences?
Call the manufacturer to confirm but they should be within 1/4" of each other. The closer the better but I think you are definitely on the outside the tolerance of acceptability. You can try and increase the short one with a lot of air for an extended period of time.
Jeff Lee 7494 D/S '70 AMX
Old 04-30-2012, 07:46 PM   #3
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Slick size differences?
I also heard that keeping the aired-up short one in the sun and flipping it like a burger a few times will help also!
Old 04-30-2012, 11:39 PM   #4
cad
cad's Avatar
Liked 93 Times in 52 Posts
I had a pair that were 3/4" different. The steering pulled to one side or the other depending on the side the odd one was on. Hoosier recommended stretching. Issue fixed as soon as the new set went on.
Old 05-01-2012, 09:48 AM   #5
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
I had the same problem w my goodyears 3/4inch. tried stretching, nfg.
I set tires by measuring around them and not tire pressure as I was tought by a drag racer friend who always measures to get tires equal over making equal pressure.
I have to set one at 11, one at 14.5. I hope to afford a real pair this year.
I know its tough to find your tire size, good luck.
car looked good at 4 wide, sorry I did not get to introduce myself as I was helping a friend and his son in SuperStock.
Chris
chris ok is offline   Reply With Quote
Old 05-01-2012, 02:16 PM   #6
buzzinhalfdozen
Liked 11 Times in 8 Posts
Art, though I've never done it or heard of a drag racer doing it my nephews who circle jerk race do it all the time. They will overinflate a tire, leave it in the sun for a bit all the while checking it's circumference, when it's close they'll let the excess pressure out and remeasure. It takes a while but seems to work for them. WARNING! this is a procedure that people who go round in circles perform use at your own risk! Joe
Joe Buchanan SS/BX 3117
Old 05-02-2012, 08:58 PM   #7
michael mercer
Liked 2 Times in 2 Posts
Art, are those the tires i shipped out. Thats a lota difference on a 20" tire.
You running a diff or a spool?
michael mercer is offline   Reply With Quote
Old 05-02-2012, 09:13 PM   #8
art leong
Hi Mike (thanks again). I'm running a spool. I haven't put those tires on the rims yet. But wear hole wise they have more rubber than any of my other 20" M/T's .Saturday I tested a pair of tires with plugs in them (and they held air after the run), and a set of 22" M/T tires.
The tires that are different circumference are the new 8 x 20 x 13" tires that are made for asphalt racing.
I'm going to try the inflate and leave in the sun method starting tomorrow. Because the tires are for oval track racing they purposely gave me different sizes. If I can't fix them myself I'll see if they can send me another pair that match.
Going down the track the car was pulling hard to the right. I thought it was torque steer made worse by the wheels sticking out 3" more than the others. Due to the wrong backspacing.
Art Leong 2095 SS
