Old 03-19-2012, 04:58 PM   #1
Pistol Pete
Pistol Pete's Avatar
Liked 816 Times in 215 Posts
Default Winch recomendations
I have a 3200 lb car. What size & brand name should i buy. Thx
Pistol Pete is online now   Reply With Quote
Old 03-19-2012, 05:14 PM   #2
Sean Marconette
Sean Marconette's Avatar
Liked 282 Times in 78 Posts
Default Re: Winch recomendations
Superwinch. I have a SW 5000. You cannot have enough winch.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 03-19-2012, 11:53 PM   #3
Run to Rund
Liked 56 Times in 29 Posts
Check speed of the winch also. You really only need about a 2500 lb winch at most, because you aren't picking the car up. I have used a Dutton Lainson 2500 lb hand winch for decades and it isn't hard to turn--I don't even use the extra gear reduction shaft for the handle.
Old 03-20-2012, 06:20 AM   #4
Kevin Panzino
Kevin Panzino's Avatar
Liked 778 Times in 142 Posts
Originally Posted by sean marconette View Post
superwinch. I have a sw 5000. You cannot have enough winch.
Sean
x2
Old 03-20-2012, 08:56 AM   #5
novassdude
Liked 136 Times in 49 Posts
I have used a 3500# superwinch for alot of years never a issue.
novassdude is offline   Reply With Quote
Old 03-20-2012, 09:27 AM   #6
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Winch recomendations
Sean
I have the same winch (3500lb. Stocker), after about one year it started to squeal very badly. I called the factory and they told me to take it apart and grease all the internal moving parts (mostly gears etc). I did as he told me and it is quieter than when new. I don't understand why they aren't greased from the factory? A great winch otherwise! Jim
Old 03-20-2012, 09:31 AM   #7
Larry Curtis
Larry Curtis's Avatar
Liked 9 Times in 2 Posts
I use the Warn 3700 pound winch with my 3500# stocker. It is a great winch and have put them in many of my friends trailers without issues.
Larry Curtis is offline   Reply With Quote
Old 03-20-2012, 09:54 AM   #8
Sean Marconette
Jim,
That is good to know! One of those things that never see any maintenance.
I have had my SW 5000 on my open trailer mounted under the steel bed, and have pulled a 57 Belair 4 door on it several times. That thing was made when metal was metal. It's a tank! My point is you may use the winch for something other than a light race car.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 03-20-2012, 12:10 PM   #9
Phillip marvetz
Phillip marvetz's Avatar
The winch companies recommend that you have a winch with a rating of double the weight of the vehicle you will be winching. I think this only applies if you are dragging a truck out of a mud hole though,lol. I've always used a warn 6000lb unit. It will drag anything onto the trailer, Flat tires and all.
2009 V/SA Record Holder
Old 03-20-2012, 12:14 PM   #10
tj310
I have a Superwinch 2000 lb it pulls the 3000# car no problem. I double up the cable for the 4200# wagon kinda slow but it gets the job done.---Trevor
