Liked 5 Times in 4 Posts
went to put my rebuilt rear end back under the future stocker, lost my u-bolts and a guy who does leafs sold me new ones, gave me 4 u-bolts, do i need to throw the little bolts that were on the bottom side to hold the bracket for shocks away? thanks y`all,
#2 | |
type car and year you are talking about. Also some better explaination on what parts you are asking if "ok" to throw away. It may be best to send a few pictures of your differential and shock set up also. ed |
#3 | |
Liked 461 Times in 92 Posts
Bob Bender 144 O/SA 2010-2012 National Record Holder |
on the rearend on the inside where the axle tubes lay on the springs, where the shock mount comes up underneath the axle, there were twobolts about 1 1/2 long factory bolts that helped secure the plate where the rear shocks mount and your u-bolts mount on other side of springs, hoppe this helpsi`ll try to get my computer guru to add pics if needed, thanks y`all
Sounds like you are describing the T type bolts some used in place of the u-bolts. You can use either. What are going with for traction aid? I would lean towards what that system uses for hardware.
Doug Blackley 1697 STK |
Liked 33 Times in 15 Posts
Get rid of the T bolts and use the U-bolts.
Joe Marcinowski 3377 STK |
