Old 02-15-2012, 03:37 PM   #1
ss/bs4457
Default Strange front brakes dragging
Does anyone have any suggestions on how to stop this?
Jonathan Womack
ss/bs4457 is offline   Reply With Quote
Old 02-15-2012, 04:05 PM   #2
Michael Compton
Liked 59 Times in 13 Posts
Default Re: Strange front brakes dragging
Jonathan -
Dad and I experienced this same exact problem on the Cavalier he bought last year except that his would lock up and not release. We ended up completely disassembling the calipers, cleaning them and replacing the o-rings. We also did everything we could to make sure they were aligned properly with spacers and such. He ended up buying brand new calipers, pads and master cylinder and it corrected the problem. Some design change had been made since the calipers he had on the car. The new ones are black now and his were a chrome color.
I replaced my brakes 2 winters ago and went with Mark Williams. I would never put another brake on my car other than Mark Williams or Lamb. The quality of their products in unbelieveable when compared to the other brands out there. You can really tell it when comparing the other brands to theirs side by side.
If you have any questions, please give my dad Mike a call at 800-268-5915. We fought those brakes for weeks before finally fixing them. He would be more than happy to anwer any of your questions.
Michael
Michael Compton is offline   Reply With Quote
Old 02-15-2012, 07:04 PM   #3
Stock4106
Liked 10 Times in 4 Posts
Jon,
I'm having the same problem with new Strange brakes I installed on my car. I called Strange about a week ago and was told that normally when they drag it is due to the line lock not fully releasing pressure and if it's not that then something is wrong with the calipers. I changed my line lock and they still drag. I should have listened and bought the Lamb brakes.
Owen S. Birkett
Stock/Super Stock 4106
Stock4106 is offline   Reply With Quote
Old 02-15-2012, 07:26 PM   #4
Ty Kwaiser
Ty Kwaiser's Avatar
Liked 33 Times in 11 Posts
Jon, before tossing out the Strange brakes, replace your braided line to the caliper. A small crack or piece of debris can cause this too. We know from past experience. Been there and done that. Ty
Ty Kwaiser is offline   Reply With Quote
Old 02-15-2012, 09:01 PM   #5
pmrphil
Liked 397 Times in 153 Posts
Might want to double-check that the master cylinder pushrod is retracting all the way - if the spool valve is in the wrong position it will not release pressure.
Phil Molski
PMR Performance
S/C 1623
Old 02-15-2012, 09:25 PM   #6
Bill Edgeworth
Check to see if your pads are wearing evenly. I have seen issues on some cheaper calipers (Aerospace) where once the pads have worn significantly (and unevenly) the the piston cocks in the bore making the brakes lock. Especially in the ones with the composite pistons.
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
Old 02-15-2012, 09:28 PM   #7
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
x's-2 for the win. the pads wear tapered from hard braking. that's what cuases it.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 02-15-2012, 10:24 PM   #8
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
The newer Strange Calipers have two different size pistons on their 4 piston calipers. The new calipers solve the problem that wears the pad into a wedge shape. Good Product !!
Old 02-16-2012, 09:51 AM   #9
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
X2 on the pushrod adj.
make sure there is some freeplay on the pedal.
Try cracking the bleeder open when the brakes are draging , if it frees up, the problem is not in the brake caliper.
If the brakes still drag , check the rotors for "belling" and make sure the caliper bracket has been mounted correctly and are not bent .
Severely tapered pads indicate either a missaligned caliper , or belled rotor.
Check what you have thoroughly before spending $ thousands on something that is easily repaired.
Old 02-16-2012, 10:02 AM   #10
Tom Goldman
Talking Re: Strange front brakes dragging
Joe, were we reading each others minds?
