Old 12-02-2011, 12:24 AM   #1
bdixon
Liked 15 Times in 7 Posts
Default 83/4 mopar rear gears
I was wanting to know what rear gear lube everyone is running is stock...
I pulled my gears out this week and found broke tooth on ring gear and am now putting all new in and i want to know what works best ...thanks in advance for any info Bryan stk5010
bdixon is offline   Reply With Quote
Old 12-02-2011, 12:46 AM   #2
House of Darts
Liked 20 Times in 15 Posts
Default Re: 83/4 mopar rear gears
I've always used regular gear oil with limited slip with my spool w/o any problems. Many of the Mustangs that run the NMRA and the 8.8 Ford rear have very good success with Redline Synthetic gear oil. The shock additives are superior. Many of these guys run 4-5spds.
House of Darts is offline   Reply With Quote
Old 12-02-2011, 01:42 AM   #3
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
How many runs, how fast and what is the weight of the car. The lube has less to do with early failure than, improper setup. If you are using the Richmond street gears or something similar, they never get the proper break in they need and are a little too hard for a fast drag car. Although it would be totally impractical, if you could put a few thousand street miles on a properly setup Richmond street set before it went into the race car, it would last much longer. Most of the fractures that become failures are born on the first few runs.
Old 12-02-2011, 09:48 AM   #4
bdixon
The car weighs 3245 and gear set is 7 or 8 years old and was due to be changed just wanting to know if synthetics are the way to go or not thanks
Old 12-02-2011, 10:16 AM   #5
John Dinkel
Liked 265 Times in 69 Posts
The oil probably doesn't have anything to do with broken teeth. Proper set up is important. You could try having the ring and pinion Cryogenicly treated. It will help extend the life of the gears. Jim Bailey does this. www.finishedracing.com
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 12-02-2011, 09:45 AM   #6
ETDragRacer
What weight gear oil for summer use? Why do you run limited slip additive? Thanks!
ETDragRacer is offline   Reply With Quote
Old 12-02-2011, 12:19 PM   #7
John Duzac
John Duzac's Avatar
Liked 83 Times in 20 Posts
Smile Re: 83/4 mopar rear gears
Mark Williams recommends 75-140 Richmand Synthetic gear oil. Sells for about $9.00 a quart. This gear oil is GL-6 rated! You can go to any auto parts store and find 5 rated gear oil. GL6 rated oil is hard to find. This oil is excellent and it helped ring gear life. This oil is blue in color and can be reused. GL6 rated oil is the best! It is just that simple.
John Duzac D/S 4448 STK
John Duzac is offline   Reply With Quote
Old 12-02-2011, 07:32 PM   #8
Jeff Teuton
Liked 325 Times in 50 Posts
Send your new ring & Pinion to Bailey, get the treatment, make sure your brace on the housing is good, triple tighten the U bolts. I assume you have a 742 housing and spool. We use Royal Purple, and since I used Jim the first time 4 or so years ago, have not broke on in my 69 6 pak, or any of the new Challengers. Hope this helps.
Jeff Teuton 4022 STK
Old 12-06-2011, 03:47 PM   #9
njk53
Still have a couple of gallons of whale oil I use with a friction modifier. No issues
Nelson Kowal
Stock 345
Old 12-06-2011, 04:24 PM   #10
Run to Rund
Liked 56 Times in 29 Posts
I believe the MW oil is Torco. I have had good results with Lubrication Engineers LE 607 and the newer LE1605. Even with pro gears, I like to put a few miles on them (30-50) before racing, if possible.
