Liked 7 Times in 6 Posts
The shot below is at MIR with 9.5 pounds in a 32x14 on a 13" rim. I'm not sure exactly how far off the line it is, but I'd say at least 15-20 feet. Judging by the wrinkles, I think I need way more pressure. What should the tire look like this far out? Thanks for your help.[IMG]
Liked 3,252 Times in 989 Posts
From the angle I can't tell how much roll you've got, any idea how much more loaded the Right side is? Also, car weighs about how much and how is it set up? 9.5 lbs sounds like plenty to me so other variables may be in play...
#3 | |
Liked 13 Times in 9 Posts
Decals look nice on the car.
![]() Doesn't matter what the tire looks like. Keep raising the tire pressure until it spins, then back it off. Run as much as you can get away with consistently. The car will work better on both ends of the race track, and you won't wear out the sidewalls on the tire so quickly.
#5 | |
At MIR I think I could have run much more air and still hooked. I adjusted the shocks up a click, but never tried more air. Thanks for your input. Should I go up 1/2 lb at a time? Last edited by Ron Gusack; 08-17-2011 at 09:38 PM. |
Throw 11-12psi in them and see if it sticks! Then baby steps.
Agree on the shipping boxes... sorry about that. I get them started, then pull taunt and squeegee. Typically, any small bubbles will disappear over time when exposed to the sun. Vinyl is somewhat permeable, and it'll 'suck fast' to the window. They are laminated, so they'll last.
