Old 08-03-2011, 03:16 PM   #1
IanM
Default 1972 Mustang CJ pure
I'm new to the forum. I have a 1972 mustang cj that I'm working on and would like an opinion as to whether this car would work in pure stock.
Thanks,
IanM
IanM is offline   Reply With Quote
Old 08-04-2011, 04:44 AM   #2
Bobby Zlatkin
Bobby Zlatkin's Avatar
Default Re: 1972 Mustang CJ pure
Yes, that could be made into a good IHRA pure stocker. Would probably run C or D pure stock.
But, you would be restricted to IHRA only until you really got serious and were willing to spend to bucks to become a real stocker. Then you could run both IHRA & NHRA. Would probably run E or F stock.
I am assuming your CJ is a 351 Clevland.
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
Old 08-04-2011, 08:29 AM   #3
IanM
This is the low compression cleveland 351 cj. Does anyone run this combo in either stock or pure stock?
Old 08-04-2011, 12:35 PM   #4
Bobby Zlatkin
Two running stock that I can think of off the top of my head are Tex Miller & Gary
Glazner (sp?). Both have been running the same combo for many years.
Old 08-04-2011, 04:40 PM   #5
Bill Harris
Liked 26 Times in 13 Posts
Is your engine the factory rated 266HP or 275?
There are several guys that are running various 351C combos in stock. Garry Glazener in Div 2 has beat on this combo for years. Also Bill McClister in Div 4 has run this combo and has gone a second under this year. Nitro Joes stats also show Steve Kathary in Div 7 running this engine. All of these are in E/SA although Garry runs his in F/SA occasionally too.
I think Tex Miller used to run his Mustang as a '72 with this engine, but it is listed as a '71 recently, but still with the 351C. He has also beat on this combo for a long time.
Note that this engine has been hit with a lot of HP over the years. The 266HP engine is now at 328Hp with an automatic, 319 with a stick. The 275 engine is rated at 325 for the automatic and 330Hp with a stick. It is interesting that the 275/325 engine with an additional point of compression and a bigger, mechanical cam is rated lower than the 266/328 for automatics.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 08-04-2011, 05:51 PM   #6
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Smile Re: 1972 Mustang CJ pure
.....and as a result, it is the version favored by most.
Dave Turner
SS/GT #1153
Old 08-05-2011, 09:55 AM   #7
Mike Graham
Liked 341 Times in 67 Posts
You might want to consider converting it to a 73 cj. By far the softest combination.
Bumper and grill for the car. Heads (D3-aa),intake and carb. The spreadbore is a little tricky
at first.but it works.
Mike Graham is offline   Reply With Quote
