Liked 275 Times in 87 Posts
Looks like the new Mustangs and all Mopars and GM Stockers are the only ones to get to run the aluminum 3d member cases. If you have an older Ford car you can't run an aluminum 3d member, regardless of what is said in the rule book of the last several years. It was legal in 2008 to present, now its illegal. If you have a 2008 Mustang and up Stocker you are ok, but not 2007 and down. If you have a Mopar new or old you are ok as is the 12 bolt aluminum cover for GM.
NHRA in all their infinite wisdom has decided that a 4 year old rule is now not legal if you have an older Ford Stocker. Really makes sense don't you think? RJ |
Liked 389 Times in 168 Posts
Not sure why anybody would bother with an alunium cover on a 12 bolt GM rear. The factory steel cover doesn't weigh a pound. It's just stamped steel.
Ed Wright 4156 SS/JA |
Ed
Its for support and strength, not weight loss. Hope you have your problem fixed RJ |
#4 | |
I can see a stick needing that. Won't know if it's fixed until Friday.
Well, lets see. I have a magnesium 8 3/4 housing from the 70's, I think that will be legal,LOL. Or maybe the Dana 44 aluminum center from a Jeep will work,. Jack asses!
2009 V/SA Record Holder |
Liked 2 Times in 2 Posts
The ONLY reason I can think that they are doing this for is to prevent the Mopar racers from using the V-10 Drag Pak unit in older cars,as it has a production 9" "aftermarket" rear end.Just a thought.
But to me I don't see the advantage of disallowing any aluminum OE style center section in stock,there is no performance gain.
Nautilus Racing |
Liked 13,934 Times in 1,299 Posts
RJ,
If you have an old Mopar, you can not use an aluminum center section. I guess you can't call it a new rule because they have not added an amendment or change the rule book. They just say that's what the rule means. From what I have read on NHRA, the Racer Update section, its not legal in anything expect special production cars. The rules still does not make any sense to me. We are allowed to replace the rear with a same manufacture. What happens if the aluminum is the only one available. Is it legal if I replace the center section with aftermarket steel? How about if it is made of Titanium. |
Ken
I had gotten incorrect info on the Mopars, my bad. Did you receive any feedback from NHRA on your letter?? I still can't understand how a rule that was over 3 years old now is out the window. What was their thinking on this? Really makes you wonder what is going on, really makes no sense. RJ |
#9 | |
Jim Wahl....NHRA #2239 S/SS - IHRA # 8 Stock, D2 Stock Champion (forever I guess) 2019 Baby Gators Stock Champion 2009 D2 National Open Stock Champion 1981 D2 West Palm Beach LDRS SS Runner Up Past President, Southern Stock / Super Stock Association. ![]() Last edited by Jim Wahl; 04-07-2011 at 01:03 PM. |
I did not receive a response, but I do know Glen Gray read the letter. At first I thought they were going to let us use it. When they posted the interpretation of what the rule means, well lets just say I was disappointed.
It makes no sense, I can run a C6 with 904 internals, I can run a aluminum spool, but I can not use something that has no performance advantage. I will have to to invest a $1000 plus to replace the aluminum center sections that i have been using for the past three years. I don't think NHRA realizes how many racers this will affect. |
