Old 04-03-2011, 08:56 PM   #1
racer913
Default blocking tree for bottom bulb
I was wonder how many stock /superstock guys use the blocking method when leaving off bottom bulb and if you do what is easiest way to practice and set up car ?
racer913 is offline   Reply With Quote
Old 04-04-2011, 09:24 AM   #2
CJ Perry
CJ Perry's Avatar
Default Re: blocking tree for bottom bulb
I block in my super stock car. I can't block in the stocker I drive. Me personally I can't foot break it and block due to not being quick enough. Blocking is a mental thing....key is a good blinder. I want to make a metal one.
CJ Perry
9931
PCA-1
CJ Perry is offline   Reply With Quote
Old 04-04-2011, 11:12 AM   #3
LittleBubba
ive tried in both stock and superstock, and it didnt work for me, but i dont know if you have a full cage or not but jegs sells the blinder that clips to the roll bar and when i tried it, i just brought a piece of chalk with me and before i was prestaged, marked where it needed to be cut to where it was only revealling MY prestaged and staged bulbs, third yellow, and green.. takes some time to get it set up right but im sure if you just ask someone who uses one, they'd let you make a template from theirs to avoid all the trial and error time. hope this helps
LittleBubba is offline   Reply With Quote
Old 04-04-2011, 11:25 AM   #4
mannymen
Liked 13 Times in 7 Posts
I ran them in my camaro and will never run without one again if bottom bulb racing. First you have to determine how consistent and quick you are on a Pro Tree. If you can't hit a pro tree .400, then you probably wouldn't want to go the blinder route. Hate to say this, but age may play a factor for most as does the TB button you use.
I cut 8x4 pieces of aluminum and mounted them to the roll cage with helmet hooks. I then just cut out a small piece so I could see the bottom bulb only. I tried cutting out a small section to see the pre-stage and stage bulbs, but I didn't like it for some reason. So now I lean to the side while staging while still keeping focus on where the bottom bulb is and then very slightly lean back to see the bottom bulb only.
For those who can watch the whole tree kudos to you, but I can't. I flatout stink at that as watching the bulbs come down kills me. It's kind of like watching your opponent go down track as you're still sitting there.
N/A
mannymen is offline   Reply With Quote
Old 04-04-2011, 02:26 PM   #5
chevy620
Banned
Once you get it trimmed and get out there and practice with it. Don't get discouraged, it will probably suck a little at first.
Next on your list is to "backlignt the blinder" with some yellow side marker lamps if you race at night. It cuts the "flash" coming around the blinder at night, without I'm junk.
**One more thing to consider: if you are consistent blocking but are late, try smaller diameter front tires. We used to qualify with tall ones then install the shorter front tires to help with the tree..
Good luck
chevy620 is offline   Reply With Quote
Old 04-05-2011, 04:02 PM   #6
racer913
Thank you all for your help
Old 04-05-2011, 04:46 PM   #7
K Stubbs
Liked 20 Times in 3 Posts
They are pupular but I have never tried it.....Yet
K Stubbs is offline   Reply With Quote
