Old 03-23-2011, 08:28 PM   #1
Ed Wright
Ed Wright's Avatar
Default Help!!
I hope you guys have an idea about this. When I let go of the trans brake button my car has begun to cut off & back on real quick. About a tenth off in 60' when it does it. Often only first pass of the day. I have tugged on wires, tightened grounds, replaced the trans brake solenoid, MSD box, crank trigger, disconnected the tach, etc. The battery voltage to the XFI ECU doesn't change when it does this. Two new NAPA batteries also. Only thing I wanted to replace last week was the microswitch on my Biondo button. Have a new on now. Going to test again Saturday. I would appreciate any ideas.
Thanks, Ed
Ed Wright 4156 SS/JA
Old 03-23-2011, 09:15 PM   #2
Chad E532
Chad E532's Avatar
Liked 54 Times in 7 Posts
Default Re: Help!!
Ed,
Have a look at this product from Shogun.
https://www.shogunindustries.com/cgi...ew_item=101003
It might be worth a call up there to see what their engineers have to say about your issue.
Chad
Chad E532 is offline   Reply With Quote
Old 03-23-2011, 09:52 PM   #3
Ed Wright
Ed Wright's Avatar
Default Re: Help!!
Chad, a couple of years ago I asked about that and was told it was illegal for SS. I have wondered about a simple capacitor to try to dampen posdible voltage spikes. Pete Peery says he has a microswitch not open cleanly so it was bumping the 2 step again. I waited too long last week to find another microswitch and the problem was still there at the track Sunday. New one on it now, just looking for more things to look at before I take it back out Sat.
Thanks.
Old 03-23-2011, 10:07 PM   #4
Ken Etter
Liked 87 Times in 9 Posts
Default Re: Help!!
I had an intermittant miss in my SS car. Drove me crazy,tried everything.Turns out it was the microswitch in the TB button. The vibrations would make it activate the 2 step. I replaced the switch and mounted the button on rubber to try to isolate vibrations.
Ken Etter 7375 STK/5 SS
Ken Etter is offline   Reply With Quote
Old 03-23-2011, 10:23 PM   #5
Myron Piatek
Liked 138 Times in 51 Posts
Question Re: Help!!
If it's only on the first pass of the day, perhaps it could be something related to the carb/jetting/vacuum signal. It may be momentarily too lean because the engine isn't "heat soaked" from previous runs and bogging.
Old 03-23-2011, 10:39 PM   #6
Chad Rhodes
Default Re: Help!!
now you're gonna have Ed searching all over that LT one for a CARBURETOR. I know he's old but don't mess with him like that, lol.
Chad Rhodes 2113 I/SA
Old 03-24-2011, 11:32 AM   #7
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Wink Re: Help!!
Thanks, Ed
The REAL solution to your problem is a Jerico transmission. That way you don't have to worry about a transbrake button going bad. LMAO!!!!!!!!!!!
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 03-24-2011, 11:41 AM   #8
Chad Rhodes
Default Re: Help!!
I like your style
Old 03-24-2011, 12:47 PM   #9
Ed Wright
Ed Wright's Avatar
Default Re: Help!!
Originally Posted by Chad Rhodes View Post
I like your style
Big help there Chad. Big help. :-)
Old 03-26-2011, 04:18 PM   #10
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Help!!
I've spent all morning going over my car. I'm trying to get all those little things that never get fixed or looked at taken care of. Someone on here talked about a T-brake tripping at the wrong time. I got to looking at my switch and figured out I was having a similar problem. Last week my T-brake activated going up on the front end lift and going across the parking lot to load up and leave the alignment shop. You know, just a momentary thump/stumble type of apply. Well, best I can tell the little micro switch was set up in the button with partial travel already used up.
I could move the plunger less than .010 and the V/O meter would indicate a circuit. I think the odd /harsh vibrations of my little "V6" was shaking the switch enough to make a intermittent circuit. I took it all apart, moved the slope on the rod .040 and took the diameter of the rod where the switch roller rubs down to .340 depth. the switch lever starts to make contact @ .319. so I now have approx .045 travel in the plunger before the switch completes the circuit. (running SS I don't need the instant apply like a super class car) I also have the switch roller in a position where it is not touching anything when the switch is at rest. My thought there is no harmonics going through the switch lever. Well, I'll try to check it out next weekend. I think I'm going to find that thread and add my findings.
Ed, while I was reading this I thought of another issue that could be your problem.
If theses switches are all set up so close on the travel could the little spring in them cause a slight snap back when you release it? You know, like a valve bouncing on the seat. I always used a couple of shims on my switch and the spring seemed pretty soft so I tightened the spring up a couple of rounds. I figured I could take the shims out if it got too fast. Since it's been three years since I used a T-brake and I added a few B-days to myself I figure I've slowed down. :~) Good luck with it.
Adger Smith (Former SS)
