Old 03-07-2011, 09:43 PM   #1
Billy Harper
Liked 138 Times in 22 Posts
Default 69 nova rear wheel back space
looking for correct backspacing for rear wheels 30x9 rear slick have 15x8 wheels now with 4 1/2 bs and they rub outside . put a 15x10 with 5 bs would not fit
BILLY HARPER
Billy Harper is offline   Reply With Quote
Old 03-07-2011, 10:09 PM   #2
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: 69 nova rear wheel back space
Billy: I'm running a 69-72 Nova in stock.I run the old centerline wheels with 4-7/8 back spacing. I have about 1/2 inch clearance on the outside and about 3/4 inch on the inside. I believe you could probably run 5 inch backspacing if you needed to , depending on how low your back end of your car is. Hope this helps.
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 03-07-2011, 10:59 PM   #3
Jim Cimarolli
Liked 166 Times in 46 Posts
With an overall rear axle assembly width from outside the axle flange to flange of 60.5 inches I use a 10 inch rim with 6 inches of backspacing.
Jim Cimarolli is offline   Reply With Quote
Old 03-08-2011, 10:42 AM   #4
Bill Pomponi
Default Re: 69 nova rear wheel back space
You have a PM
Bill Pomponi is offline   Reply With Quote
