Old 01-02-2011, 03:44 PM   #1
borninamopar
Default Gettin' back into it..
Hey, I am considering getting back into the game.. Haven't done much over the last 10 years...Little street racin' and bracket racin'... I have a 64 dodge 440 model 2drhdtp... how would the car do with a 383 in it and what class would I have to run? I am open to any ideas and suggestions.. I would like to run stock but may consider ss. Thanks alot. Edward
borninamopar is offline   Reply With Quote
Old 01-02-2011, 04:02 PM   #2
1299
Liked 54 Times in 12 Posts
Default Re: Gettin' back into it..
383/305/305- e f g car and the 383/330/280-h i j
1299 is offline   Reply With Quote
Old 01-02-2011, 04:39 PM   #3
GTX JOHN
The 383/280 is a great Combo. It supersedes to 915 67 Heads which are much better. Chuck Rayburn ran one this year in his 64 Ply. and ran well. Good Luck and let me know if I can help.
Old 01-02-2011, 05:05 PM   #4
borninamopar
Hey thanks John... Yea, I had seen where Chuck Rayburn was running a 383.. Since I have a pile of that stuff, blocks, cranks heads etc..I have a set of the 66 915 heads with the 1.60 exhaust valves, but can I use the 67 heads with the 1.72 exhaust valves. I thought running stock you had to have the stock size valves? And why is the other member suggesting I get a chassis guy... Not much you can do to a stock chassis? I am a damn good engine guy myself and I have a tranny guy. So I got that end of it. I appreciate all the help.
Old 01-02-2011, 07:28 PM   #5
borninamopar
Hey John... I have a nice 98 Dakota R/T that a friend suggested that I build for stock too. I have seen these trucks do well in stock. Either or..I hope to have something at the track by spring.
Old 01-02-2011, 09:01 PM   #6
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
The 915 heads came in two varieties, the standard heads had the 1.60 exhaust valve, the HP version had the 1.72 exhaust valve and was stamped HP on front of the head. These heads were came on the 440 HP on my 1967 GTX.
Old 01-02-2011, 04:40 PM   #7
Jim Bailey
Liked 584 Times in 94 Posts
Wink Re: Gettin' back into it..
Get hooked up with the right people. ie: Engine builder, Chassis builder, Carb Guy, Tranny Builder, and Header guru. Spend right around 50 grand. Then maybe you'll be able to run within three tenths to a half a second of the new Drag Packs and Mustangs. Come on in ...the water's fine. JB.
Jim Bailey is offline   Reply With Quote
