Old 12-06-2010, 09:29 PM   #1
TinSoldier 3215
Liked 6 Times in 5 Posts
Default best heads for LT-1
what do you all thing? after market afr heads or trickflow heads and what cast# this is for a bracket car. What do some of you engine builder think? Thanks
TinSoldier 3215 is offline   Reply With Quote
Old 12-07-2010, 09:37 PM   #2
Tom Turner
Default Re: best heads for LT-1
I need more info to answer. What size engine? (350, 383, 398??) F.I.? Stock intake? Tell us more about what you are doing and you will probably get several responses.
Jeff Lee would have chimed in by now but that only proves that he doesn't know much about LT1's...........EVERYTHING else, just not LT1's. TT
Tom Turner is offline   Reply With Quote
Old 12-08-2010, 06:17 PM   #3
TinSoldier 3215
383 and the intake is a lloyd elliot!!
Old 12-08-2010, 11:47 PM   #4
Tom Turner
Aftermarket heads are best for you. I've used some of the AFR heads and was satisfied with the quality and results. The stock heads are too small for your app, even the LT4 stuff is probably not as good and very pricey. Someone else may have another opinion.
Who is Lloyd Elliott? TT
Old 12-18-2010, 03:48 PM   #5
Rob Petrie E395
Liked 216 Times in 77 Posts
Mine is a 398 LT1 I ran the AFR 210CC heads with a Edelbrock Lt4 Intake that was ported by Lingenfelter Performance untill now. I just got a set of AFR227's and I am freshening the engine and switching to shaft rockers and throwing a little more compression at it for next year. If you would like more info let me know I will try and type it all out. The car can go 9's in decent air with a good track with a Ed Wright tune up in the stock PCM.
Old 12-18-2010, 06:08 PM   #6
Ed Wright
Ed Wright's Avatar
I would avoid the Trick Flow heads myself. I have a friend with a 383" LT1 who has oil drain back issues. Full valve covers at the finish line are of no value. My old foot brake bracket engine ran mid/high nines @ mid 130s at 3200 lbs with ease. Still had the 4L60E trans. Pete Incaudo (was CNC Cylinder Heads) did the LT4 heads & intake. I would choose AFR if I was going aftermarket.
Ed Wright 4156 SS/JA
