Old 12-03-2010, 08:39 AM   #1
navamotorsports
Default Information on Hot Rod
What electronic devises are needed to be able to run Hot Rod and be competetive. I have an MSD box with the two step, the car has a trans brake and I also run a Biondo Wizard Delay box. I know I need a throttle stop, which one is the best on the market. Any help provided would be appreciated. I would be running Division Four IHRA Hot Rod if all works out. Thanks.
navamotorsports is offline   Reply With Quote
Old 12-03-2010, 08:54 AM   #2
jmcarter
jmcarter's Avatar
Liked 3,252 Times in 989 Posts
Default Re: Information on Hot Rod
First you need to read this...
http://www.biondoracing.com/tips.shtml#throttle
And then call them at Biondo's and they can match the stop to your combo....Sal and really everybody there is easy to talk to and can set you up.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
