Old 11-29-2010, 06:55 PM   #1
Chris Hill
Liked 244 Times in 26 Posts
Default 2002 Dodge Ram Dash
New dash from Dodge for a 2002 Ram 1 ton is $432 to $549. Is anyone aware of a less expensive option to replace this cracking dash? I've heard of a dash pad you glue to the existing dash, but this one has a large hole already (10" x 20" or larger).
Thank you,
Chris Hill
Old 11-29-2010, 08:18 PM   #2
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: 2002 Dodge Ram Dash
It's a cheaper but very time consuming option, but if you find one at a junk yard/you-pull-it, you can learn how it comes apart on the doner truck before you do yours.
As for a dash pad, it may be possible to fill any "holes" in the dash with some type of foam, (expanding?) before covering it
Old 11-29-2010, 08:58 PM   #3
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
Default Re: 2002 Dodge Ram Dash
Where is it cracking?? I have a 2002 and the part of the dash by the windshield has cracks,but the rest if crack free.I think the cracked part of mine is separate from the dash pad area itself.
FWIW..my neighbors 99 Dodge dash cracked all over and he got a dash pad carpet deal from Pep Boys and it worked great.
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 11-29-2010, 11:12 PM   #4
201250
201250's Avatar
Chris I have the same problem with my 2002. It has holes in it!!! Why dodge didn't recall these is beyond me. There are actually 3 pieces. One piece along the windshield,one below that and the main dash cover. I have not found a CHEAP replacement. Do a google search on 2002 ram dash as you probably have. I've got to fix mine as I'm trading it in next year. Let me know if you come up with something.
TC
201250 is offline   Reply With Quote
Old 11-29-2010, 11:26 PM   #5
FED 387
Liked 333 Times in 180 Posts
My neighbor had similiar problems called Chrysler 2 weeks ago and was persistant got them to give him $250 towards a new dash---Comp
Old 11-29-2010, 11:31 PM   #6
rayfin
See COVERLAY...
http://www.coverlaymfg.com/store.php...-pickup-22-805
I installed many of these. Install in 5 minutes. You're welcome.
rayfin is offline   Reply With Quote
