Old 10-20-2010, 03:52 AM   #1
GTX JOHN
Default Dana 60 Housing Straighting
Went to put Dana in my Demon and noticed Housing was visibly bent by eyeball inspection. Can they be straightened? If axles go in easily after fixed are they straight or should they be dial indicated. I guess I might be smarter replacing axle tubes? Do you know anywhere that straightens them in So Cal/Nv/Az.
Appreciate any feedback....Thanks
Old 10-20-2010, 12:27 PM   #2
mopar jeff
mopar jeff's Avatar
Default Re: Dana 60 Housing Straighting
How about getting ahold of Phil Mandella at PMR race cars. He might know someone. Good luck.
Jeff Interlicchia
7077 D/SA 1998 Pontiac Firebird LT1
J707 E/T 1966 Dodge Coronet 500
mopar jeff is offline   Reply With Quote
Old 10-20-2010, 01:05 PM   #3
Rod Greene
Liked 242 Times in 81 Posts
John since it is bent have Phil put the molly tubes on it. Just make sure he puts the right spacing for the brakes. On my Challenger he put ford spacing on one side and Mopar on the other.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 10-20-2010, 01:40 PM   #4
Philip Saran
Liked 14 Times in 11 Posts
John,
If not Phil Mandella, try Ed Sutton @ Sutton Engineering in La Habra CA.
it is on Imperial Blvd off Harbor Blvd in the old Boyd Coddington hot rod facility.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 10-21-2010, 01:18 AM   #5
GTX JOHN
Rod does that housing (your old one) have stock tubes on it now...I take it you recommend CM. IS it MW axles spool?
Thanks
John Irving
Old 10-21-2010, 04:36 PM   #6
Rod Greene
Yes John it was a stock B body housing narrowed for the Demon. It has MW 40 spline rifle drilled axles and aluminum spool.
