Liked 539 Times in 112 Posts
Has anybody actually seen any benefit switching to axles that have been gundrilled for weight reduction? I know in theory they should be quicker, be what about real world results that amount to a measurable amount of difference. Thank you in advance
Jim Kaekel 3836 STK |
I didn't actually see a change but you have to believe all the little reductions add up. So does the cost. Is it worth it? If you want to be all you can be I guess it is. Thats what the army says.
Liked 336 Times in 183 Posts
Think of it this way for every pound you lighten on a rotating mass the engine sees it as a 4 times reduction --the further out rom the center of rotation it can multiply even more---so if you take out 2 pounds of axle the resistance that the engine has to overcome is approx. 8 pounds plus the car actually weighs less also--Comp 387
I have never noticed an quantifiable difference.....quit putting them in any of our cars about 5 years ago......not saying there is not something there just have a lot of other places to throw money at for us!
Several years ago I put the whole lightweight rear package in my 3600 lb. A/SA Camaro. Aluminum spool, lightened ring and pinion, rifle drilled axles with all extra metal removed from the flanges, titanium studs, etc. Took 24 lbs of rotating weight out, put 24 lbs in the box.
Total improvement was ----------------------- nothing!!!!!!! Nothing in 60', 330' or anywhere else. Might be some help in a lightweight car with a low torque engine, I don't know, but no one I have talked to ever said they picked up anything except a lighter wallet.
John Mason 7743 SS |
#6 | |
Liked 269 Times in 99 Posts
