Old 09-14-2010, 08:52 PM   #1
428tom
Default Hoosier drag radial air pressure?
Just wondering how much air pressure to run in a 30x9 hoosier lightweight drag slick on a 10 inch rim.Car is a 2800 pound fox body Mustang auto?
428tom is offline   Reply With Quote
Old 09-14-2010, 09:56 PM   #2
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Hoosier drag radial air pressure?
I run 21 lbs in those same Hoosier slicks on 10" rims (94" circ.). My car weighs 3,540 +, but most people I've talked to are between high teens and low 20's. Lots of variables between vehicles, but that should give you a starting range.
It will be interesting to see if anyone is much lower or higher, especially in lighter cars.
Old 09-14-2010, 10:21 PM   #3
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Exclamation Re: Hoosier drag radial air pressure?
I run 22 lbs on good track and no less than 18lbs. If it doesn't hook with 18lbs then I make a shock adjustment. Same tire and weight as Myron. Jim
Old 09-15-2010, 01:37 AM   #4
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Wink Re: Hoosier drag radial air pressure?
I run 20lbs on a "not so good" track & 25lbs on a good track
Old 09-15-2010, 07:55 AM   #5
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Default Re: Hoosier drag radial air pressure?
19-21 lb......
Old 09-15-2010, 11:09 AM   #6
jim reid
3100 lbs 1987 camaro I run 28- 30 lbs. hooks 99.9%
jim reid is offline   Reply With Quote
Old 09-15-2010, 03:32 PM   #7
west coast
Liked 230 Times in 75 Posts
I have run as high as 26psi with out a problem my car does not have alot of power. Fox body at 2965lbs low 1.60 sixty foots 1.59 twice 5.0 stocker
west coast is offline   Reply With Quote
Old 09-15-2010, 07:51 PM   #8
GTX JOHN
22-25 in 3700 wagon....1.52/60 19-22 in 3300 Demon 1.36/60 Both calvert springs and nearly 50/50 weight.
Old 09-15-2010, 08:09 PM   #9
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
ran them at 24 psi on a good track 3660 lbs car,,check the track for bald spots and stay out them !!!!! gmonde
Old 09-15-2010, 09:08 PM   #10
nwebber
Liked 39 Times in 5 Posts
30-36 in a 3600# L/SA wagon
Norm Webber
nwebber is offline   Reply With Quote
