Old 09-13-2010, 08:03 AM   #1
dragginwagon
Default Impala wagon rear end
have been told that no matter what I do 10 bolt rear end will not stand up to launching 4000lb wagon...any thoughts ??
dragginwagon is offline   Reply With Quote
Old 09-13-2010, 09:37 AM   #2
Jim Cimarolli
Liked 166 Times in 46 Posts
Question Re: Impala wagon rear end
8.2 or 8.5 10 bolt?
Engine size?
Stick or auto?
Jim Cimarolli is offline   Reply With Quote
Old 09-13-2010, 10:12 AM   #3
dragginwagon
Default Re: Impala wagon rear end
327 275 hp 4 speed is the drivetrain I plan to use...other wagons I have seen are using extremely low gears in rear end... 6:14's??... thanx
Old 09-13-2010, 10:16 AM   #4
dragginwagon
forgot to add...8.2" I believe as it is original to car...67 Impala
Old 09-13-2010, 11:09 AM   #5
Liked 1,826 Times in 414 Posts
The problem with that much gear in a small 10 bolt is the pinion is going to be about the size of your thumb.
Old 09-13-2010, 12:10 PM   #6
dragginwagon
Is a GM 12 bolt my only other option if I want to run stock? my 10 bolt measures 56 1/2 " backing plate to backing plate...
Old 09-13-2010, 12:24 PM   #7
If you can get the right gear, you might be able to run a later 10 bolt, maybe something from a full size wagon or sedan from the eighties, some of them had the big 10 bolt.
You might be able to run something beside the 12 bolt. There might be a small savings in weight, drag, and initial cost. However, gear life could be a serious problem, and buying gears, installation kits, and paying for labor could get expensive fast. The slower cars are successful by being stone reliable and consistent. Remove some reliability and the slow cars are at more of a disadvantage.
