Liked 64 Times in 14 Posts
I had a new Magna Fuel system installed on a 69 Camaro stocker
I ran a test and tune today and the car was off as far as ET I checked the fuel pressure and it was at 3 pounds I brought it up to 6 pounds and the car stumbled on the launch and the 1-2 shift on the next run I had always thought the fuel pressure for a Q JET should be at 7 pounds or so Any thoughts on what might be causing this? The car is very rich as you can smell the fuel all around the car when it is run
Mark Callanan 1027 STK |
Liked 203 Times in 52 Posts
Check air door tension and float level.Could also be pulling fuel into sec.
Kevin |
Liked 56 Times in 27 Posts
Mark,
Has the carb been apart for any reason, jets-etc ..? Did you have a stumble/miss with 3 lbs of fuel pressure when you first started ? Sounds like maybe float or needle is sticking and fuel is bleeding by ? Is it clean driving around in pits & on starting line....? Maybe Danny will jump in if he is around ? Top of 1-2 shift usually points to flapper valve adjustment ? I would take carb apart and check over really good, look for dirt or something in needle & jet area and make sure things haven't fall into bowls ... Good Luck, keep us updated & talk to Vic Santos, he's very good with Q-jets.........
Dave Ribeiro 1033 STK |
#4 | |
David The car the 1st run ran fine but didnt run the number by a tenth Thats why I checked the fuel pressure and it was at 3 pounds So I turned it up Running around the pits is fine the car starts up fine and runs fine The carb has not been touched and has been perfect till now I think it may be a bad pressure gauge Thanks David for stepping in here to help it is kind of you We had to turn it up alot to get it to 6 pounds and again there is alot of fuel smell I will look for a gauge in the morning...
Liked 1,443 Times in 302 Posts
I remember in the manual with the magnafuel stuff I bought it reminds you to check the fuel pressure at an idle, not with the engine off. I also have heard several different people commment on how far off some of the fuel pressure gauges could be.
James Schaechter 3163 STK |
Mark, If using the big needle and seat (I think it is 0.135") in your q-jet, try running no more than 4-5 psi max, the float bowl will stay full. Higher psi never worked well on my 455 Pontiac either.
MWNorris |
Mark,
I would try another gauge, if you can't find one , turn the pressure down to 4 lbs and see how that runs & feels ? If it works , it may get you by for this weekend .... If it doesn't work, adjust in 1/2 lb increments till it get better... Could try another carb ? Also , try ; turning on the pump & look down into carb to see if it's bleeding over with too much pressure ? ........... Good Luck .........
#8 | |
Good call the gauge was bad
Mark,
Glad you found your problem & congrats on your Win @ the Last IHRA event at NED ....
