Old 09-07-2010, 06:29 AM   #1
randy wilson
Liked 22 Times in 22 Posts
Default cranking compression
Does high cranking compression slow a car down?
don,t have one
Old 09-07-2010, 09:35 PM   #2
JOE B
Default Re: cranking compression
Maybe.. need alot more info to get a better answer.
JOE B is offline   Reply With Quote
Old 09-08-2010, 11:22 AM   #3
SSDiv6
Liked 1,583 Times in 582 Posts
X2
Need specifics about the engine such as type of cylinder head, static compression, cam type, etc...
Old 09-08-2010, 07:23 PM   #4
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 306 Times in 103 Posts
depends on why you have high cranking compression? Cam advanced will raise cranking
compression as one example,duration, overlap changes cranking compression,valve lash can change it.
compression works both ways like high spring pressure you have one cyl. compressing have another that just fired and is pushing another piston down. just like on valve springs people claim strong springs use power,but when you are opening one valve another is closing it evens it out. proof of that is turn engine with one valve adjusted it will be all you can do to turn engine each one you set engine gets easier to turn when all are set engine turns easy .
have you raced much this year? I got to go about 4 times set IHRA F/PS record at Mountain Park Pro Am 4th July weekend went 7.997. May go to UMTR race at Owingsville Ky. this weekend maybe Doorslammers at Ohio Valley.
Maybe give more info on what you've got going on might be able to help give me call if need to.
Mike Taylor 3601
Old 09-08-2010, 09:34 PM   #5
art leong
Mike Taylor 3601
Another weird note is that 4 cyl DOHC motors can get awful high and still like it. I run 290 pounds. Got crazy when I found out tried to lower it and ran a lot slower.
Now I just accept it as one of those things I don't understand. Like how they get those ships in the bottles. LOL
Art Leong 2095 SS
Old 09-09-2010, 06:31 AM   #6
randy wilson
Thanks guys, here's some details, advanced cam 1 degree, widened valve lash .003, went from 213 to 256 cranking compression, picked up 19 lbs torque, 21 hp with single 4, 51 hp 39 lbs. torque with duels, slowed down a tenth and 3 mph, doesn't make sense to me. The reason we don't go back is we tightened up compression, and that's where everything has to be set. Maybe we just haven't found the sweet spot yet. Will be running at eddyville this weekend in the last modified lbs. per cube, no break-out race this weekend, and we need to have our ducks in a row.
don,t have one
Old 09-09-2010, 02:06 PM   #7
Mart Jeltema
Liked 10 Times in 2 Posts
Arrow Re: cranking compression
Mike Taylor is correct. If the average is better, then look at the jetting. When my Brake Specific # looked good on the dyno and didn't perform on the race track thats where I head. I have found on a car with a hood scoop needed to increase the jet size. On my single carb 750 I had to increase the jets 3-4 #'s.
Mart Jeltema is offline   Reply With Quote
Old 09-09-2010, 12:33 PM   #8
randy wilson
We are up 3 sizes since dyno. It was real slow before that.
don,t have one
Old 09-09-2010, 08:17 PM   #9
Jeff Lee
Jeff Lee's Avatar
Then keep going bigger until it slows
Jeff Lee 7494 D/S '70 AMX
Old 09-09-2010, 09:40 PM   #10
junior barns
Liked 20 Times in 14 Posts
Question Re: cranking compression
what happens when you have no scoop and not much hood to carb clearance?
junior barns is offline   Reply With Quote
