Old 07-24-2010, 09:16 AM   #1
chester
Default strange spool problem
i bought a complete strange 3rd. member and went to install it and the mark williams 40 spline axels are not long enough to reach the splines inside the spool, it seems markwilliams splines start at the outside edge and go all the way thru the strange spool splines are in about 2' from the edge does anyone know if strage makes a spool to match or do i need to pitch the stange stuff a go back to mark williams. thanks chuck rothermel
chester is offline   Reply With Quote
Old 07-24-2010, 12:04 PM   #2
Lou SG2340
Default Re: strange spool problem
You need to get a Mark Williams Spool or Strange Axles, I would think the spool would be cheaper
Lou SG2340 is offline   Reply With Quote
Old 07-24-2010, 02:03 PM   #3
Adger Smith
Liked 880 Times in 311 Posts
I ran into the same problem a few years ago with a car I bought. I had a Strange 40 spline 3rd member with a slightly diff. gear ratio that I wanted to use. Ended up swaping the spools. Later replaced the Strange 4 spline with a Motive Gear 40 spline spool. Seems all the 40 spline spools an axels have the same pitch/size spline.
Adger Smith (Former SS)
Old 07-24-2010, 02:29 PM   #4
chester
thanks fellas, i bit the bullet and disassembled 2 3rd members to make one, just wish they had told me that theirs is different than the rest, now i need a spool and gears instead of just gears, o well chuck
Old 07-24-2010, 06:30 PM   #5
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
don't panic strange makes a spool with thru splines , they go all the way across, and will work with the m/w axles just call them. they will probobly swap it for you if it's new. they are great to deal with . just give them a call. i always order all my third members with this spool.it keeps the axles shorter to save a little weight.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
