Old 06-26-2010, 10:09 AM   #1
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Default single plane vs sheet metal intake
With runners being equal and on the same engine which would make the most torque in the 4000 to 6000 rpm range using a single 850 cfm carb.
astikhossw is offline   Reply With Quote
Old 06-26-2010, 10:30 AM   #2
Liked 1,952 Times in 439 Posts
Default Re: single plane vs sheet metal intake
Not nearly enough information.
And if the runners are the same, there's no point in the sheetmetal intake anyway. The idea behind the sheetmetal intake is to do things that the cast intake does not.
Old 06-28-2010, 08:27 PM   #3
Ron E
Also, it's not unusual to see a single-carb'ed sheetmetal intake have twice the EGT spread of a single plane.
Ron E is offline   Reply With Quote
Old 06-28-2010, 09:59 PM   #4
Jeff Lee
Jeff Lee's Avatar
I've spoken to many a racer that spent the big bucks on a sheet metal intake and not picked up a thing; sometimes losses are experienced. Design and workmanship may not be on the level necessary or harmonics can be an issue.
I am having a sheet metal intake built for my AMC and I quiver as I've heard more bad than good on the subject. But my choices are few, a small Torker or too big Indy or HLR intake (vintage NASCAR). Plus I forced myself into sheet metal because I decked the block quite a bit.
Jeff Lee 7494 D/S '70 AMX
Old 06-29-2010, 06:07 AM   #5
Ron E
Jeff, you pretty much sum up the real reasons one would need a sheetmetal intake at least for a single carb. Beyond that, it's mostly "cool factor".
The manufactures will tell you what to hear. I've heard of 2 tenths being promised over the phone. In reality, he picked up nothing.
Old 06-29-2010, 09:04 AM   #6
SSDiv6
You are correct. There have been only a few engines that have picked up because there was not a good cast aluminum racing intake available to start.
