Old 06-01-2010, 10:11 AM   #1
Mike Galuk
Smile Clutchless trannys in SS Modified NHRA
What does NHRA allow in SS Modified, Clutchless 4 speeds or 5 speeds or both. Any help would be appreciated. Thank you, Mike
Mike Galuk
JOE COOL RACING
M/SA-2000
Mike Galuk is offline   Reply With Quote
Old 06-01-2010, 10:59 AM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: Clutchless trannys in SS Modified NHRA
Recent rule change; you can now run clutchless in traditional SS and that trickles to the modified. Traditional SS still has to run the correct number of forward gears as per OEM.
Jeff Lee 7494 D/S '70 AMX
Old 06-01-2010, 03:06 PM   #3
Stephen & Horace Johnson
Liked 166 Times in 54 Posts
are you sure about that last sentence??? lol I thought the 55-56's bel air's could run 4speeds now....
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 06-01-2010, 04:08 PM   #4
LB Racing 3179
55's and 56's are allowed to run 4-speeds. The Modified classes are allowed to run 5-speeds.
LB Racing 3179 is offline   Reply With Quote
Old 06-02-2010, 10:49 AM   #5
Robert Simpson
Liked 20 Times in 12 Posts
This is true, in any car that came with a 3sp manual standard, can now have a 4spd. BUT, this only came about AFTER nhra allowed powerglide combo's only, can have a 3spd auto. Man what a mess....I think there is a weight break diff between the Sticks and Autos in SS Modified? That needs to be lifted.
Robert
Robert Simpson is offline   Reply With Quote
Old 06-02-2010, 11:41 AM   #6
randy wilson
Liked 22 Times in 22 Posts
I still think modified stock is still limited to 4 gears, i thought that might be lifted beings i think lots of the newer cars come with 5 gears. Correct me if i'm wrong.
don,t have one
Old 06-02-2010, 11:42 AM   #7
Jeff Lee
Jeff Lee's Avatar
Yep, forgot about those 3-speed manual exclusions. So how much did those pick up with the 4-speed conversion? It sounds like those that lost the PG in exchange for a turbo type trans picked up a bunch.
