Liked 54 Times in 7 Posts
I recently switched to an ATI converter and in their instructions they require a type F fluid that is red in color. Prior I was running a TCI converter with a lower stall and the TCI green fluid and had a very firm shift. With the ATI with a slightly higher stall the shifts are not crisp at all. I am wondering if this could be due to the Type F fluid I am running or due to the higher stall or possibly a combination of them both.
I would like to try a different fluid to see if I can get a crisp shift again. Any recommendations on which brand(s) of Type F that are red in color that work the best? Thanks Chad |
Liked 99 Times in 60 Posts
Chad,
you may receive as many opinions as if you ask about motor oil ![]() My experience is this, the trans shift "should" be fine with any fluid. I have run type "F", Dexron, hydraulic fluid, and "race fluids" and seen no significant difference in any of them. (we are talking about medium horse power, foot brake applications) These days I run Dexron/Mercon type lll because it is easily available and performs fine for the above mentioned application. I suspect your "less than firm shift" is not fluid related. |
Liked 4 Times in 4 Posts
I've run type F in my Mopar since I built it and never had a problem.
At a Nss race in LA (lower Alabama) I had to use Wal Mart off the shelf atf and still got crisp shifts. Talk to your converter guys and see what they have to say. JimR
Jim Rountree |
Liked 69 Times in 32 Posts
i doubt the fluid has anything to do with it, it should actually shift harder with type f as
it has almost no friction modifier in it.
Ron Mattson 5015 STK |
Liked 33 Times in 17 Posts
I was told early on that the type F holds up better under higher temperatures.
Liked 3 Times in 1 Post
Chad, all of the above suggestions are right on, your shift feeling has nothing to do with the Fluid, that is if you have enough Fluid in the tranny!
Woodro Josey 2002 STK |
Liked 485 Times in 160 Posts
Strange, I talked to ATI last year about my set up, ATI TH400 and ATI converter (foot brake) and was told to use Dexron III fluid. I mentionned I had been using Ford FA , with no issues and they said switch to the Dexron III. Just shows ask 2 or 3 people and get 2 or 3 different responses.
Just to add to "the mix".
I use type FA with a bottle of lucas. |
