Ok lets hear it....Will anti roll bar fix it? Mine is the Camaro someone was nice enough to send me the pics.. Car only has 4 point cage, I am welding in the door bars and re-enforcing the frame connectors this week, will that help?
Eric Bowling |
Still got leaf springs?
Yup has Afco multi leafs on it, bout 2 seasons old..
Eric Bowling |
Check your centering pins
Liked 883 Times in 237 Posts
Or the location of the new spring mounts. ..Better string line the rear before doing anything else. ..........Tom
Liked 19 Times in 7 Posts
You better build your own sway bar and build it super strong. Most antiroll kits are designed for cars that dont cork over that hard. I have a stock suspention malibu that used to leave on the passenger door handle. I looked at buying one but they were way too lightweight. I built my own and built it bomb proof and I still tweeked it. You car looks good with the mini tub and it would be nice to fix the problem but would it be possible to put the shocks back into the stock location and try it?
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A |
I have pulled both rear shocks and both feel exactly the same. i was just curious to see which side you would put the extra shock on. I have tried everything but puttin an anti roll on it, had some extra shocks so thought I would try it, just didnt know whether to try limiting the seperation on the drivers side or compression on the passenger side.
Eric Bowling |
Here are some more pics of the car and I was lucky enough to win the Scotty Richardson No Box Race this weekend so I threw in a pic of he and I in the winners circle!
Eric Bowling |
I checked the pins on the rear, they are good, also string checked it that is good. We put the shock back as close to the stock location as possible and angled the tops in a touch, it didn't help at all. I have installed the door bars as of last night hopefully that will help a bit and I will just throw an anti roll at it, I would love to see some specs and materials of one that you made for yours. Thanks for all your input.
Eric Bowling |
Looks a lot like some serious frame and roll cage stiffness problems to me.
Alan Roehrich 212A G/S |
