Liked 4 Times in 2 Posts
Playing with the carb on my 440. it seems to not want idle very well at low RPM, there is no check ball under the pump squirters, will that affect anything. also curious about primary jet size and metering rod, the jet has a 120# and a 497# with a .045 rod
Jim : I run .113 and .095 Jets on Stocker. .045 on bottom step is OK. The 1968 up cars ran a 3 step metering rod with cupped retainer while 1967 back had 2 step and flat top.....also as I recall a shorter primary jet. If you mix combo up it will run like cr*p. If you are in Vegas, I would be happy to take a peek at your carb or loan you one if you guys promise not to put that male s*x doll in my Demon again. John Irving
Thanks John,Does that jet # sound like a real # for the jet i can't see it very well it's so small. ONE MORE TIME I DID NOT DO THAT X-Rated Doll thing to you!!!! Mark Faul you will read this at one point??? Time to fess up dude.............ha ha ha
The AVS doesn't use a check ball inder the plunger. There's an inverted brass needle under the squirter.
John, this thing has a flat retainer for the rod! and the rod is 3 step that is .045-.070-.080 it just sounds to me that someone tried to peice this carb together and make it work. doesn't supprise me one bit.i have redone this whole car besides the carb. I guess on the possitive side of this i have a good car now......................
Liked 25 Times in 16 Posts
My understanding of the AVS and AFB carbs is that the three-step rods can be used with the AVS primary jets (taller than the AFB jets) and the domed piston/rod covers. The two-step AFB rods use the flat covers and the shorter AFB jets. I haven't tried swapping the two around. I keep with the AVS setup in an AVS and the AFB in the AFB carbs. The trick is finding the AVS parts and jets. The Edelbrock Thunder AVS series seem to use the AFB two-step rods and jets.
Mopar 2 Ya! |
You can run the AFB/Edelbrock perform carb 2 step rod and jet with the FLAT cover in an AVS. But if you use the AVS 3 step cover and 2 step rod and jet it won't run right. The AVS uses a taller jet, longer 3 step rod and the cover with the bump in it. The secondary jets are all the same. The last #'s on the jets are simply the hole size in thousands. If it ends in 95 it's .095 diameter hole in the jet.
I would think it would idle ok unless the primarys are open enough to pull fuel through the primary metering circuit, which may be the case in a low vacuum situation. First check the throttle shafts for play and a possible air leak. If they are ok you may have to drill a 3/32 hole in each primary throttle blade to give it a little more air flow. If it seems better but still dies out make the holes a bit bigger. I'm sure the guys that know these carbs could tell you which air bleed to open up to pull more fuel/air through the idle circuit. The AVS is very simple but can be tricky, when right they run very well. |
#8 | |
