On a TH 350 transmission what is the inlet and outlet thread size for the trans. lines? I always thought they were 1/4 pipe but I am not sure. Anyone know?
Nelson Kowal Stock 345 |
Liked 541 Times in 112 Posts
1/4" NPT is correct. Just keep in mind that most NPT to AN adapters (Aeroquip, Earl's, XRP, etc.) are actually NPT tapered pipe fittings. Be very careful tightening these type of fittings into the case since you can break the case in this area if you get carried away with a wrench.
Jim Kaekel 3836 STK |
Liked 8 Times in 1 Post
If you are going to use braided hose for cooler lines , use the original brass fittings that were in the trans along with Aeroquip FCM 2111 fittings. They are1/2-20 inverted flare to #6. This will allow you to attach #6 hose to the trans. I know these fitting are also available from Earls and Russell but I do not have there Part number handy.
Tom
Brian Van Poppel 1682 SS |
Liked 54 Times in 7 Posts
I just ordered up fittings for my TH350 a couple weeks back. The thread on my case (1977) was not 1/4" NPT but actually 1/4" NPS which is a straight pipe thread. ATI makes the fittings to go to -6 or -8 AN fittings.
The part number for the -6 is 925137, I ordered mine through Jegs but you could also order direct from ATI. Thanks, Chad |
Liked 6 Times in 4 Posts
My trans is an early 70's model is there a possibility they wet to a 1/4 NPT to a 1/4 NPS when they changed over to metric fasteners? My intent is to use a Jiffy-Tite quick connect at the trans both inlet and outlet.
