Old 12-02-2009, 08:53 PM   #1
Philip Saran
Liked 14 Times in 11 Posts
Default To add back brace or not?
I'm looking for feed back/opinions on wether or not to add a back brace to
the 8-3/4 housing in my Duster. Car is presently a bracket car, may some
day move up to SSGT, but probably never become a 360 stocker.
Present 383 makes less than 400 HP, 10 inch convertor and 4:56 rear
with a set of 4:88 sitting waiting and Goodyear 9x30x15 slicks.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 12-02-2009, 11:04 PM   #2
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
Default Re: To add back brace or not?
Phil,
I'd use the brace.Have the brace welded in without the axles in,and make sure the housing is straight afterwards.
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 12-03-2009, 12:38 AM   #3
Philip Saran
Chris,
Thank you for your input.
Phil Saran
Parker, Colorado
Old 12-03-2009, 01:07 PM   #4
Everett Vassar
Originally Posted by Chris DeGidio View Post
Phil,
X2 on this---When I bought my 440 Duster Had 8 3/4 with sure grip No problems
Then the s/g broke, I upgraded to a full spool.Car would not even get 60ft without going hard right
Rearend hsng was bent. Had it straightened and brace welded on with no more problems.
Everett Vassar is offline   Reply With Quote
Old 12-04-2009, 08:53 AM   #5
Leon Rennebaum
Everett: Could you explain how the housing was straightened??? Just curious!
Leon Rennebaum is offline   Reply With Quote
Old 12-04-2009, 10:28 AM   #6
Chris "drooze" Wertman
Chris "drooze" Wertman's Avatar
On a 9in unit I had in my TR7 it was when all the stuff (brackets, brace,etc was welded) on it warped it. they did some cutting and rewelding, straight as an arrow. Pisser I had it coated before checking it
Chris "drooze" Wertman is offline   Reply With Quote
Old 12-04-2009, 11:51 AM   #7
Chuck Beach
Chuck Beach's Avatar
Liked 58 Times in 13 Posts
Send a message via AIM to Chuck Beach
Definitely brace the back and put braces on the spring purches front and back. There is not much to those housing when they are apart. Moser can weld the back brace and the braces on the purches and they will make sure it is straight .. my .02 ...
Chuck Beach
3340 STK
Chuck Beach is offline   Reply With Quote
Old 12-08-2009, 01:04 PM   #8
Everett Vassar
I wasnt there to watch him do it,But he said he had to heat it up.Then probably used a hyd press.
