Old 09-21-2009, 07:03 PM   #1
Rick Shirey
Default 60' times
What are some of the things you look at when your 60' times fall off ? Mine have fallen off by around a tenth.I have already tried the usual, new tires,float level,fuel pump delivery,timing,transmission and even went as far as having the converter cut apart.Thanks in advance.
Rick Shirey is offline   Reply With Quote
Old 09-21-2009, 08:15 PM   #2
69ss/rs
Default Re: 60' times
Go over the car from top to bottom and look for any suspension binding,any thing broken,bad shocks, bad heim ends etc.
69ss/rs is offline   Reply With Quote
Old 09-21-2009, 08:15 PM   #3
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Check the oil for bearing material -- make sure it's not the engine going away. Been there, done that...
Old 09-21-2009, 09:36 PM   #4
Ed Martin
Ed Martin's Avatar
You can also check the compression and the valve springs. Sounds like the engine may be a little tired.
Ed Martin
SS/IA 910
Ed Martin is offline   Reply With Quote
Old 09-22-2009, 02:23 AM   #5
Marty Rinehart Jr
Marty Rinehart Jr's Avatar
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
Rick, you should really start by comparing your on track incremental times and mph of the good runs to the bad. You can then make a better pinpoint of the spot where your losing your power. If your mph is up at 660 and 1320, then you can come to a conclusion, it's not the engine, trans or converter. Look at the other incrementals and find where it's dropping off and if it's only the 60' times that are slow. It may be as simple as the track your racing at may not be preparing the starting line properly due to the car counts being down. They could be trying to make up their profit margin there. I know a lot of the points races we ran at this year, we had to keep the car very loose to make up for a bad track.
Just another opinion. Hope it helps
Marty Rinehart Jr
1125 SS STK SG SC SST
Marty Rinehart Jr is offline   Reply With Quote
Old 09-25-2009, 09:59 AM   #6
Jack McCarthy
Liked 511 Times in 122 Posts
leak / comp test motor... maybe banged a few exhaust valves
jack
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 09-26-2009, 08:26 AM   #7
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
For my car it's the head gaskets leaking between cylinders when the 60 falls off, Paul.
