Old 07-18-2009, 03:12 PM   #1
John Lang
Liked 6 Times in 2 Posts
Question Clutch Help
A friend that I help has a 63 Corvette Gran Sport clone , one of those Road Racer things! He is haveing clutch trouble as in it is starting to slip. He doesn't have any oil leakage problems, it's adjusted right,and only about 400 mi of pretty hard driveing ! It's got a 572 Chevy Crate motor, the720hp version, with a 5 spd, and a 4.10 rear gear! The tires are some road race stickys, about12" wide, the car weighs approx ,2400 # w/driver, and it now has a Centerforce clutch thats starting to go away ! I suggested a dual disc, I just didn't know about brands ,or who to see ! Anybody got any Ideas ? The car is mint and it's been to Bloomington several times , just to screw with some of the judges ! Thanks in advance , John
John Lang 365 STK, SS
John Lang is offline   Reply With Quote
Old 07-18-2009, 04:54 PM   #2
Bill Belden
Bill Belden's Avatar
Default Re: Clutch Help
Advanced Clutches
Call Rob Youngblood: 208-880-6214
Advancedclutches.com
Bill Belden
Retired Stock Eliminator
[emailSTK1100@comcast.net[/email]
Bill Belden is offline   Reply With Quote
Old 07-19-2009, 09:12 AM   #3
Liked 1,826 Times in 414 Posts
That car shouldn't need a trick clutch. But I don't think anything Centerforce has is up to the task. I'd be looking at a Borg & Beck / Long style pressure plate with some centrifugal assist, and a sprung hub paddle clutch, probably 6 pucks, with a moderately aggressive friction material.
Old 07-19-2009, 02:16 PM   #4
John Lang
Smile Re: Clutch Help
Thanks for your help ! I will tell him as he is also an old fart, and loves his toys ! He does get kind of nuts at times ! We have Road America, at Elkhart Lake, just 24 miles away, but most times he plays on the side cty rds, Thanks........... John I,m more of a Mopar person but jeez does that thing fly ! He is also got a 65 Corvette coupe, with i think they call it an LS7 ? Its a 427 sb with a dry sump etc. Some other time !
Old 07-20-2009, 01:11 AM   #5
Jeff Lee
Jeff Lee's Avatar
There are several dual disk units from just about any seller that would probably be appropriate for this application. Any would depend on the level of work the guy wants to put into it (is this track only?). A dual disk diaghram unit would be the easiest to set up (just bolt it in) and if he's not into setting records for lap times and just wants to go have fun, it should be fine IMO. But if he has sticky track tires and is putting a big load on everything, it could break parts and or loose traction (could cause a wreck) just like a drag car. You can adjust the slippage on a diaghram clutch by increasing the installed height. I would suggest a data logger is a necessity if he's looking for that level of tuning.
Jeff Lee 7494 D/S '70 AMX
Old 07-20-2009, 08:29 AM   #6
Troy Henderson
Troy Henderson's Avatar
Liked 129 Times in 41 Posts
If your serious about finding what the clutch capacity of his application would need to be Patrick Hale makes some nice software..
http://quarterjr.com/clutch_pro.htm
Troy Henderson
Henderson Race Shop LLC 816-520-5389
www.hendersonraceshop.com
Troy Henderson is offline   Reply With Quote
