Old 07-02-2009, 02:42 AM   #1
rick lester
Liked 4 Times in 1 Post
Question Ihra stock fwd classes...
i can't find my ihra rulebook. can somebody, anybody email me or post here the weight breaks for ihra fwd stock classes and indexes. i know their different than nhra. i want to race with the ssssa so bad, and if i can at least get my 86 olds delta 88 with 3.8 motor to run the index, i'm going to race. nhra class df/s index 15.90 1/4, 9.86 1/8. no way car will do that, at least 1/4. i have run car in 1/8 at 9.70's with short belt and 22" tall tires on 14" rims. if i remember old nhra fwd classes it would fit e or f, can't remember which, but i think e was 16.45 or close to that. car to weight nhra around 3000, actual is 3185 with no gutting. car is my daily driver but i would not be afraid of putting on new heads. i think with a good set of heads, short tire with lightweight wheels and a short belt and electric water pump, i could at least run the ihra index. car is fairly consistent, and as long as i can cut some lights, i can go some rounds. help me out guys. FWD STOCKERS RULE!!!!!!!!!!!!!!!!!!!!!!!!! Rick.
rick lester is offline   Reply With Quote
Old 07-02-2009, 05:09 AM   #2
rick lester
Default Re: Ihra stock fwd classes...
just went to ihra site, e is 15.90, 9.85, f 16.30, 9.95. all automatic class. man thats fast, car ran 16.80's 1/4. got my work cut out for me. i want to keep it streetable. i'm not against doing a cam swap, but i don't want it too radical. i just want a index car, just intill s10 is running. rick.
Old 07-02-2009, 06:31 AM   #3
Fred Popov
The IHRA rulebook can be viewed online. Stock rules and classes start on page 54. (Enter 56 for the page in the top window to go to stock)
Here is the link:
http://www.mydigitalpublication.com/...on/?m=1203&l=1
Fred Popov is offline   Reply With Quote
Old 07-02-2009, 10:31 AM   #4
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
AF/S 13.00-15.99 14.65/9.20 stick and auto Index are the same
BF/S 16.00-16.99 15.15/9.45 stick 14.95/9.35 auto
CF/S 17.00-17.99 15.30/9.55 stick stick and auto are the same
DF/S 18.00-18.99 15.45/9.65 stick 15.60/9.70 auto
EF/S 19.00-19.99 15.60/9.70 stick 15.90/9.85
FF/S 20.00-23.49 15.80/9.70 stick 16.30/9.95
GF/S 23.50-27.49 16.75/10.45 stick 17.20/10.75 auto
HF/S 27.50-more 17.75/11.05 stick 18.60/11.85 auto
NHRA, AF/S is 13.00-15.99, 14.15 Index. BF/S 16.00-17.49, 14.95 Index. CF/S 17.50-18.99, 15.45 Index, DF/S 19.00-24.99, 15.90 Index, EF/S 25.00 and up, 17.75 Index. Stick cars must weigh 100 pounds more than an automatic in NHRA.
Old 07-02-2009, 01:42 PM   #5
rick lester
Thumbs up Re: Ihra stock fwd classes...
fred, thanks, that site helps alot! did not know that was there. mike, thanks, i needed that too. cool car, alwaysed loved those olds. so if i read it correctly, i can run f with more weight. i did weigh car couple of years ago, 3185 with 1/4 tank of gas with no spare or jack, without me in the car. if car weighs 3200 i can run it as ihra ff/sa. good heads, short tire with lightweight wheels,electric water pump, and maybe a cam, i can at least run the 16.30 index. mike, our cars are similair as far as weight and motor goes, what have you done to your olds. i don't need every little detail, and i know a higher ratio final drive will make a world of difference, are you at 430 lift? nothing is done to mine as far as performance other than no cat. i still need this to be streetable, still have all power options and air and i still will have all these on car no matter what. ed, turbo car is out of the question. i know a turbo fwd car can run the index, but this is just to tide me over until s10 is finished. i enjoy going to the races and hanging out and helping anybody that needs help, but i want to be "in the beams" so to speak. don't know if i will have everything done to it by reynolds, but i'm going to try. even though new ssssa rule is no protesting, i don't think i can tell jim car is ihra gf/sa, and get away with it. rick.
Old 07-02-2009, 01:55 PM   #6
art leong
Rick I might have a set of 20" tall 8 inch wide slicks, mounted on 6 inch wide American racing rims 5 x 100 mm bolt circle, for sale. You can try them if you want at the Valdosta race (if I get my transback together). I'm going to a larger gear so I'll be using 22's or 23's.
Art Leong 2095 SS
